***Solved***
Position Calculation
position is a diameter zone, so yeah, it doubles the radial deviationsigpic
I get that, but that is not the radial deviation. It is the full deviation from axis end point to axis end point.
same thing, the "measured value" is the zone required for the feature to be in tolerance for POSITION, you are not asking it for ANGULARITY, your cylinder goes from 0,0 at one end to "whatever" the deviation is at the other end, and for position, it makes that a diameter, not the radius that you have.
by Liambo734I have a true position callout [TP/0.500/A/B/C], no diameter symbol, so a square tolerance zone, not a cylindrical zone. I am stuck with using legacy...
01-06-2016, 05:20 PM -
by HoodlumHow do I rescale the part axis?
I need to have the positive "X" Axis for the machine going in the opposite direction.
12-09-2009, 10:48 AM -
by keegoSounds like a noob question but here goes:
What the heck is the H axis? Sometimes when reporting diameters, along with the diameter comes...-
05-19-2010, 03:55 PM -
by ShankCrusherSo, I want to make sure I understand a concept of a callout that I am seeing alot lately, and that is the reported value of a planar zone position in...
04-17-2016, 07:01 PM -
by BobE1111Is there a way to have PCDmis read only the value in one axis when you're positioning an cylinder to one datum. My basic dimension is in the Z axis 7.2000...
09-02-2021, 12:33 PM -
