I was trying to solve the thread https://www.pcdmisforum.com/forum/pc...surface-levels by using the "measured thickness box" in an auto plane.
The theo and actual values of the plane are different than the target value (what it was expected), but the actual hit values are not shifted of the thickness value.
Is it normal ?
For example (because I'm really not sure to be clear !) if you program an auto-plane at Z=0 with a measured thickness of 10, the actual and theo Z values of the plane are 10, the target is Z 0, and the hits values are Z 0.
An enhancement could be to choose if the hits can be shifted or not...
Is it normal ?
