Depends on the controller.
On a Leitz protocol, you have to turn to 0 the 4th value of REVRS and SIGN_FAC, in the constant.dat.
From the terminal button, type show REVRS, it should answer 1,1,1,1,0,0
Then type SET_PAR REVRS,,,,0
It should answer 1,1,1,0,0,0
Do the same for SIGN_FAC, and at the end
SET_PAR FILE_WRT to save.
Maybe, if you unplug the rotary, there's other parameters to change, but when I just want to avoid some controller crashes (W counter error), those are enough.
Note the init values before changing, and re-do the same in the other way when you will plug the rotary.
Hi has anybody out there got any experience with rotary tables on a cmm. Our company is looking at this due to some new work that may becoming our way....
I installed the rotary table on a Global, V2011. When I try to calibrate it, nothing happens. When I try to move/rotary table, nothing happens. But with...
