How to build this tip?
  • How to build this tip?
    Hi All,
    has anyone built this type of probe before? I have PH10M SP25M TM25-20 TP20 and then this. Previous programmer was using it for a part that is coming back now, and was wondering how to build it.
    at least 2 pieces look like adapters, is that a mix and match of M2 and M3 threads?
    Looks like M2 tip on a M2 x M3 adapter to fit on the M3 knuckle, which is sitting on another adapter to mate M2 extensions...
      to me it looks like it's the tip, knuckle, adapter and extension. i will take it apart and see. How would i build the knuckle?
        this are all the components after the TP20
          When you add the knuckle, directly underneath the component it will say joint:knuckle. Double click that and you can set the "A" angle equivalent of the tip. Double click on the knuckle itself and there's a "Default rotation angle about connection". That's where you'll set your "B" angle equivalent.
            Thank you!! That worked for me
            • D-Train
              Probe Description help
              by D-Train
              I need to build a probe tip, 5by70MM. In my probe description pulldown I see some tips labeled 5by50MM and 5by50MM_CF.....what is the CF? I have a 5by75MM_CF...
              05-08-2013, 10:15 AM
            • Addison Wood
              M2 Knuckle Joint Probe Definition
              by Addison Wood
              Running a PH10MQ with an 30mm to 8mm converter, TP20, 20mm M2 extension, M2 Knuckle, and a 1X20mm probe.
              When the PH10MQ is at 0,0 I want...
              05-09-2007, 12:03 PM
            • D-Train
              Probe Building
              by D-Train
              Running PC-DMIS CAD++ 2016.0 on a global advantage 12.22.10 using TP20 builds. We just had someone from Hexagon out to replace the Tesa Star (part with...
              06-05-2017, 07:22 PM
            • mdobb829
              Stylus Knuckles
              by mdobb829
              Has anyone used a stylus knuckle with any success? What is the difference between a regular knuckle and a rotary knuckle? Is there anything that needs...
              10-30-2010, 07:31 AM
            • WolfMan
              L-probe how to
              by WolfMan
              Hood morning fellas, I have a problem
              I want to create an L-shape probe, I only need 1 probe at A90B180, no others is that doable or do...
              02-26-2014, 07:51 AM
