2019 R2 results very different from 2017 R2 results - same part
  • 2019 R2 results very different from 2017 R2 results - same part
    We recently got a Global S Chrome new with 2019 R2 on it. We currently have a 2 or 3 year old formally EVO (almost the same as the new Chrome) that is running 2017 R2.
    Same program run on the Chrome and the former older machine with 2017 R2 gives really close results EXCEPT for the Summary Fit to Datums which is what our operators use to figure out what they need to move. I am assuming that it is a setting on the 2019 R2 machine but thought someone might have info. The two results attached were run on the same part on each machine. Can anyone explain what is going on here? The Chrome fit to datums summary cannot be correct! The 2019 R2 (Chrome) report is on top. The 2017 R2 (similar CMM - same probe - similar controller) is on the bottom of attached image.
    Construction of datums are very different between both versions, maybe the problem is here ?
    • tami_
      tami_ commented
      Same program, alignment is the same. Posting the code from each program. Looks almost exactly the same to me.
    Below is the program data from the 2017 machine.
    ALIGNMENT/LEVEL,XMINUS,PLN_X
    ALIGNMENT/TRANS,XAXIS,PLN_X
    ALIGNMENT/ROTATE,YMINUS,TO,PLN_Y,ABOUT,XMINUS
    ALIGNMENT/TRANS,YAXIS,SPH_ID
    ALIGNMENT/TRANS,ZAXIS,SPH_ID
    ALIGNMENT/END
    MOVE/INCREMENT,<0,-0.5,0>
    MOVE/INCREMENT,<-0.5,0,0>
    SPH_ID_E =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,0,0>,<-1,0,0>,0.401
    ACTL/<0.0018,-0.0001,-0.0001>,<-1,0,0>,0.4014
    TARG/<0,0,0>,<-1,0,0>
    START ANGLE 1=0,END ANG 1=360
    START ANGLE 2=-8,END ANG 2=-35
    ANGLE VEC=<0,0,1>
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=NO
    MOVE/INCREMENT,<0,0,3>
    TIP/T2A0B180, SHANKIJK=1, 0, 0, ANGLE=180
    MOVE/INCREMENT,<3,0,0>
    SPH_OD =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
    THEO/<0,0,0>,<-1,0,0>,0.479
    ACTL/<0.0016,-0.0004,-0.0001>,<-1,0,0>,0.4794
    START ANGLE 1=-120,END ANG 1=120
    START ANGLE 2=-10,END ANG 2=-34
    ANGLE VEC=<0,0,1>
    MOVE/INCREMENT,<1,0,0>
    MOVE/INCREMENT,<0,0,5>
    SCN_OD =FEAT/SET,CARTESIAN
    THEO/<0.0857,0,0.0506>,<0,-1,0>
    ACTL/<0.086,-0.0002,0.0507>,<0,-1,0>
    CONSTR/SET,BASIC,SPH_OD.HIT[1..25],,
    PNT_SPH_ID =FEAT/POINT,CARTESIAN,NO
    ACTL/<0.0021,0,0>,<-0.9999988,0.0015174,0.0001094>
    CONSTR/POINT,CAST,SPH_ID
    PNT_SPH_OD =FEAT/POINT,CARTESIAN,NO
    CONSTR/POINT,CAST,SPH_OD
    DIM LOC1= LOCATION OF SPHERE SPH_ID_E UNITS=IN ,$
    D 0.4010 0.0020 0.0000 0.4014 0.0004 0.0000 -#-------
    END OF DIMENSION LOC1
    DATDEF/FEATURE=SPH_ID_E,E
    FCFLOC1 =POSITION : SPH_OD
    FEATCTRLFRAME/SHOWNOMS=NO,SHOWPARAMS=YES,SHOWEXPANDED=YES
    CADGRAPH=OFF,REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,A RROWDENSITY=100,OUTPUT=BOTH,UNITS=IN
    COMPOSITE=NO,FIT TO DATUMS=YES,DEV PERPEN CENTERLINE=ON,OUTPUT ALIGNMENT=Datum Reference Frame
    CUSTOMIZED DRF=NO
    STANDARDTYPE=ASME_Y14_5
    PRIMARY DIMENSION/POSITION,SPHERICAL DIAMETER,0.002,<MC>,E,<MC>,<dat>,<dat>
    SECONDARY DIMENSION/<Dim>,<tol>,<MC>,<dat>,<dat>,<dat>
    NOTE/FCFLOC1
    FEATURES/SPH_OD,,
    A3 =ALIGNMENT/START,RECALL:A2,LIST=YES
    ALIGNMENT/BF2D,YMINUS,MIN_MAX,CREATE WEIGHTS=NO,ROTANDTRANS,0.0016,0,-0.0001,0
    ITERATEANDREPIERCECAD=NO
    Deviation Threshold=0.0003937
    SHOWALLINPUTS=NO,SHOWALLPARAMS=NO
    ALIGNMENT/END
    FCFPROF1 =SURFACE PROFILE : SCN_OD
    FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES
    CADGRAPH=FORM,REPORTGRAPH=FORM,TEXT=OFF,MULT=10.00 ,ARROWDENSITY=100,OUTPUT=NONE,UNITS=IN
    COMPOSITE=NO,
    PRIMARY DIMENSION/PROFILE OF SURFACE,0.002,UNEQUAL TOLERANCE ZONE,0,<dat>,<dat>,<dat>
    NOTE/FCFPROF1
    FEATURES/SCN_OD,,
    RECALL/ALIGNMENT,INTERNAL,A2
    COMMENT/REPT,
    The dimension below is FOR REFERENCE ONLY:
    DIM DIST1= 2D DISTANCE FROM SPHERE SPH_ID TO PLANE PLN_X PAR TO XAXIS,NO_RADIUS UNITS=IN,$
    M 0.0000 1.0000 1.0000 0.0021 0.0021 0.0000 ----#----
      Code from the 2019 r2 system is below:
      ALIGNMENT/END
      ACTL/<0.001,0,0.0001>,<-1,0,0>,0.4021
      ANGLE VEC=<0,0,1>
      ACTL/<0.0005,0.0005,0.0003>,<-1,0,0>,0.4787
      ANGLE VEC=<0,0,1>
      ACTL/<0.0857,0.0002,0.0507>,<0,-1,0>
      ACTL/<0.0014,0,0>,<-0.9999925,-0.0034748,-0.0016978>
      D 0.4010 0.0020 0.0000 0.4021 0.0011 0.0000 ----#----
      DATDEF/E,FEATURES=SPH_ID_E,,
      FEATCTRLFRAME/SHOWNOMS=NO,SHOWPARAMS=YES,SHOWEXPANDED=YES,
      CADGRAPH=OFF,REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,A RROWDENSITY=100,OUTPUT=BOTH,UNITS=IN,
      CUSTOMIZED DRF=NO
      SECONDARY DIMENSION/,<tol>,<MC>,<dat>,<dat>,<dat>
      NOTE/FCFLOC1
      FEATURES/SPH_OD,,
      ALIGNMENT/BF2D,YMINUS,MIN_MAX,CREATE WEIGHTS=NO,ROTANDTRANS,0.0005,0,0.0003,0
      ALIGNMENT/END
      FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES,
      CADGRAPH=FORM,REPORTGRAPH=FORM,TEXT=OFF,MULT=10.00 ,ARROWDENSITY=100,OUTPUT=NONE,UNITS=IN,
      COMPOSITE=NO,
      MIN_MAX
      NOTE/FCFPROF1
      FEATURES/SCN_OD,,
      COMMENT/REPT,
      M 0.0000 1.0000 1.0000 0.0014 0.0014 0.0000 ----#----
        What is being reported doesn't seem to match what is really there in the actuals. This was a different run from the previous report posted but the Summary Fit to Datum data is still not correct.
        • KIRBSTER269
          KIRBSTER269 commented
          I'm guessing that the bottom is 2019 version, Delete the callout and re-create it. I'm talking about your pictures being the bottom one. Xact measurement re-create
        • tami_
          tami_ commented
          Thanks, I just did that and it didn't change a thing. Exactly the same. BUT, fun fact, … when I changed the true position feature to the center pnt of that sphere instead of the sph itself, which will work since it doesn't have a material condition, it reports correctly.
