We use a Rayco table to set our parts up in freestate and are able to use iterative alignments in DCC mode. In November, the machine X axis and Y axis got switched by an operator. After fixing this, the CMM thinks the parts on the Rayco table are sitting 5 to 10mm higher than they actually are. Is there a way to adjust the Z axis on the machine instead of adjusting each individual program? I should add, we have calibrated the tips several times and they are in tolerance.
Machine alignment issues with 2014.1
Good morning,
I have a Brown&Sharpe Xcel 7-6-5 CMM. This machine is not included in PC-DMIS 2013 within the hardware definitions,...-
10-10-2015, 01:50 PM -
Hi everyone!
I am a new user of PC DMIS for CMMs and I am currently using PC DMIS 2014.
How can I know the axis of the working...-
09-13-2018, 03:50 PM -
by mr500When i lock in my X and Y axis, and move my probe only in the Z direction full span of the machine, my X and Y changes on me. A lot. X will change by...
08-28-2008, 10:41 AM -
Anyone have screenshots of your machine definitions for a Fanuc 18M controller that works? I am having issues with what the machine is reporting in the...
Channel: PC-DMIS NC
11-09-2015, 03:40 PM -
by TIMSHARMANHi there
A few years ago we purchased a global 15-20-14 to run along side our scirocco to make programs conversant between the two machines we...-
06-03-2014, 09:16 AM -
