Security
  • Security
    We have 3 CMMs all running 3.7mr3.
    Everyone on all shifts uses the same login.
    We have been providing some security by making all of the "master" programs read-only. This prevents an accidental overwrite of the master program.
    Unfortunately, this is no longer sufficient.
    What I tried to set up was a secure directory on the server that has very limited "write" access.
    I transferred a group of programs over to this directory.
    Now when we tried to run them with PC-DMIS (using the standard login that had no "write" privileges) from that directory we got the "serialization" error.
    What's up with that?
    Does PC-D write a temp file when loading a program?
    Lately, it occurs to me
    2017 R1 (Offline programming)
    Are you trying to run the programs straight from the server. I think its been posted before there is a problem doing that.
      Here is how we got around that. All master programs are on server. All operators, (and programmers), copy program from server onto local disc prior to running the program. No one ever runs a program from the server. You could just set up one temp folder and maybe a script to dump the contents of to the trash every 24 hours or something. It is a bit of a pain having to dig out and copy the program fresh for every run, but easily worth the security of always having a clean "master" program for future reference. HTH
        We have been running from the server for years. That is not the problem.
        Apparently PC-D is trying to write something while loading a program.
          Has anyone ever tried to run a program from a CD? That might be an easy way to do it.
          Otherwise, I'm thinking along Wes's line of thought. Perhaps instead of the operator transferring the program you could do the following.
          Place all your programs in a write protected folder (folder 1) on the network.
          Setup another folder (folder 2) which has full access.
          Setup a script that will delete the contents of folder 2 at some point each day and then copy the contents of folder 1 to folder 2. The middle of the night would be a good time to do this if you don't run 24-7 otherwise you might try at lunch or some other time.
          Doing that will ensure that at at least one point each day the programs in folder 2 will not be corrupted.
            I have run programs off CD's before. When the job is done, all the data, programs, etc., get burned to DVD's (used to be CD's) and they get removed from teh hard drive. Once, I had to set one of these back up (customer issues) and run some more parts, about a month AFTER the job left here, and I just ran them from the DVD. Well, if you try to CLOSE the program, you will get an error since it can not write, if you QUIT, no errors and I got no errors opening it up and running it.
              So it sounds as if you could simply burn a cd or dvd of all your programs and the operators could use those. Of course, if that works I would think running from a write protected folder would work as well.
              Perhaps John could give us some more details as to when the error occurs. When the program is first opened? When the operator starts the execution? When the program is done running and tries to save a report? When the operator tries to close the program using the close command instead of the quit command? When pc-dmis attempts to do an autosave?
                Well, th ebig advantage to useing a CD over a directory is that no matter WHAT you do, you can not over-write the program on the CD (providing it is NOT a re-writable) but you can, one way or another, over-write a file on a hard drive.
                  I suppose though the downside is that you could end up with more than one CD and would have to be changing them all the time. If you could divide the programs between different CD's in a logical manner and keep them filed properly it wouldn't be too hard to find the correct one.
                    Burn them to a BLU-RAY disk, can probably get most of ANY companies programs on one of those suckers!
                      Yeah, but who knows, they may go the way of Beta-Max?
                      I guess the key would be to store them on CD but also have a copy hidden away on the server somewhere.
                        Yeah, the blu-ray will go away, when they start using that little-bitty disk they showed us in MIB.
                          If you use HyperReports, doesnt it create an extra file in the folder where the program is located?
                            I'm going to have to buy the White album again aren't I?
                              Number 9
                              Number 9
                              Number 9
                              Number 9
                              • Gary Fitzgerald
                                Write Protection Backfire?
                                by Gary Fitzgerald
                                We have a folder (directory) over the network which contains Master CMM programs. The permissions for this folder, from the CMM's, is read access only...
                                06-03-2008, 09:19 AM
                              • lcrowston
                                Proven Programs
                                by lcrowston
                                Has anyone ran into this?
                                Some of my older proven programs have changed while saved.. I start the program and it crashes, I then look at the feature...
                                06-14-2019, 01:42 PM
                              • chris_h
                                Working from server
                                by chris_h
                                Hello all,
                                The IT department at my company want us to start working directly from the server so all of our programs would be created/saved on the...
                                05-02-2017, 03:16 PM
                              • AuRules
                                Using the SERVER
                                by AuRules
                                Need a question or suggestion.
                                Currently we run 3 cmm's directly from a server. 99% of the time each cmm is running out of a different...
                                07-22-2008, 08:10 AM
                              • Measuremanmike
                                Program Security
                                by Measuremanmike
                                Here’s one for the Wilcox moderator.
                                Why is it that we users have the onus of devising a method with which to protect our programs from unintentional...
                                02-23-2015, 11:27 AM
