Y14.5 ?
  • Y14.5 ?
    If it doesn't specify on the drawing which Y14.5 spec to use which one do you use?
    Depend on the date the drawing was derived.
    IE: 1984, Y14.5 1982
      there's a difference?
        Nobody but the designer/their company can make that call.
        If you're you're making a part, and you are NOT IN CONTROL OF THE DESIGN, and you find yourself with an under-defined bit of engineering information...you're required by almost every quality system standard to consult the design authority (whether that means ask your customer or have them ask theirs).
        I would ASSUME you'd go with the most recent revision of 14.5...but who knows?
          under-defined bit of engineering ? that just couldn't be...
