Surface Profile!!!
  • Surface Profile!!!
    I’m trying to measure the surface profile of a part. I scanned the surface using Closed Line Scan but when I try to get the results it says 0 all the time. Please help!
    You need to construct a feature set out of the scan and dimension the feature set.
    7107 Global Classic TP20
    2019R1 SP1 CAD++
      Do you have a CAD model? The hits need real theoretical values to compare to. If you just learn a scan directly on the part, all the hits have THEO = ACTL, which of course gives the result zero on a surface profile...
      • Hirxm
        Hirxm commented
        I do have the CAD model and I generated the scan by touching on the CAD model, then the machine went to dimension it.
      Did you execute the entire program? I seen behavior like this when executing just the scan.
      • Hirxm
        Hirxm commented
        Yes, I executed the whole program and nothing gets better.
      make sure it is not set to master, should be find nominals
