example of tertiary datum with MMB
  • example of tertiary datum with MMB
    Does anyone have a good example of a simultaneous evaluation of bolt circles with a tertiary datum hole with MMB? I have a guy that just can't get it.
    thanks
    Primary - Mating Face
    Secondary - Mating Cylinders
    Tertiary - Clocking slot
    With MMB on a slot, the part can rotate a bit as you depart from MMB to help line up a bolt pattern.
      It's a very crude drawing but reference the bolt holes 3X [Position|Ø .XXX|A|B (M)|C (M)].
      MMB on C will control a little rotational error. I forgot B in the side view.
      • Douglas
        Douglas commented
        a crude drawing... for me is a napkin, for you apparently solidworks
      • JacobCheverie
        JacobCheverie commented
        Douglas well thanks, it was MS Paint but I guess my skills aren't as bad as I thought
      thanks, but I need something to convince this guy he can't add tolerance to the position tolerance from the tertiary datum hole
      • JacobCheverie
        ASME Y14.5-2009 7.3.6.2.2(a)
        "Effect on Considered Features. The amount of the datum feature's departure from MMB does not provide additional positional tolerance for each of the considered features in relation to each other within the pattern."
      Look here :
      https://support.hexagonmi.com/s/arti...-1527312026428
      https://books.google.fr/books?id=XdA...%20mmb&f=false
        thanks, I wish I could print that out.
        • JacobCheverie
          Use snipping tool?
