Pc-Dmis losing sequence of dafault names,I have named a feature say pln1 pnt1, i would then expect next auto point to be named pln1 pnt2. instead it is skipping evens pln1 pnt1, pln1 pnt3, pln1 pnt5 and so on. i understand PC-Dmis just does this but i would love to save myself hours of headache, if there is a fix?
Pc-Dmis losing sequence for feature names
Originally posted by BIGWIG7 View PostWhen I am dimensioning something, PCDMIS is skipping numbers. why?
bub_01 skips to bub_03 and skips 02.
I get that problem particularly with Legacy Positions. If you select several features at once, then type in the starting name of a new naming sequence and create them all at once, the second sequence always gets skipped. However, the numbers don't get skipped if you select one feature, type in a new naming sequence, create that feature, then select all the other features and create them.
Originally posted by vpt.se View PostDoes your license include the "Even numbers" option? If not, this is what you get.
j/k - I have nothing.
I've had it where it would skip a bunch of numbers during copy-paste operations. Usually a close and re-open does the trick.Whatever a man sows, he shall reap.
by MUlissiAs the topic titles asks, can PC-DMIS automatically change an alphabetical feature name like a number?
For instance, if I make a feature...-
12-05-2019, 10:48 AM -
by vpt.seLike title.
I want to measure a point and use a feature as sample points. The featurename is PLAN_PNT1. I have another feature called PLAN_PNT14...-
11-22-2021, 04:50 AM -
by TumbleweedAnyone ever try to use a feature within a feature?
Ex. POINT1=FEAT/POINT,CARTESIAN
THEO/<0,CIRCLE1.Y,-158.65>,<0,0,1>...-
05-07-2013, 02:17 PM -
by Jeff_OrvisI received a program from Stellantis that has the following parameter: FEATURE LOCATOR=NO,NO,"F4992M324 - POINT - INSP=D METAL=0.914 TYPE=10"....
Channel: PC-DMIS Code Samples
07-08-2022, 08:16 AM -
by TestedWe are running a customers program and many of the Feature Names contain <, >, -, +, * as part of the feature names. I have always stayed away...
07-27-2006, 10:33 AM -
