Adding a usrprobe.dat file...
  • Adding a usrprobe.dat file...
    Hi, I have a question about adding a tip file.
    (3.5MR2)
    I have an existing usrprobe.dat file that has a cylinder tip in it.
    ITEM:TIP3.0BY13MMSHNK M2
    begintip
    ribcount 10
    color 142 142 142
    cylinder 0 0 0 0 0 -6 3
    cylinder 0 0 -6 0 0 -10 2
    color 255 0 0
    cylinder 0 0 -10 0 0 -14.5 3
    hotspot 0 0 -13 0 0 1 3 4 shank
    endtip
    ITEM:CONVERT_TO_M2THReD M3
    color 142 142 142
    cylinder 0 0 0 0 0 -7 4
    connect 0 0 -7 0 0 1 M2
    I just got a smaller cyl. tip that is not in my library (1.5MM x 11MM)
    Can I copy/paste/modify my existing probe file and create another usrprope.dat file? or add the new one to the existing file?
    Since I don't know what all the numbers mean after the size, I'm kind of stuck.
    Any help is appreciated as always.
    Thanks Mike
    Copy, paste, modify & make sure you rename tip
      Do I modify this existing tip?
      Do I have to change anything else besides the tip size?
      Thanks
        (3.5MR2)
        begintip
        ribcount 10
        color 142 142 142
        color 255 0 0
        endtip
        color 142 142 142
        Thanks Mike
        copy the entire section within the same (USRPROBE.DAT) file. If the length of the stylus (and everything above it) is identical, you need only to modify the diameter on the last CYLINDER line and the diameter on the HOTSPOT line.
        The Cylinder lines contains -
        geometry X1 Y1 Z1 X2 Y2 Z2 Diameter
        The Hotspot line contains -
        X Y Z I J K Diameter Length connection_type
        This is from memory, so I might be slightly off. . .
          Go...
          HERE
          ...for a document on the description of the probe files.
            Thanks
            Thanks for the input. Here is what I get now
            begintip
            ribcount 10
            color 142 142 142
            color 255 0 0
            endtip
            color 142 142 142
            ITEM:TIP1.5BY11MMSHNK M2
            begintip
            ribcount 10
            color 142 142 142
            color 255 0 0
            cylinder 0 0 -10 0 0 -14.5 1.5
            endtip
            color 142 142 142
            Probe file=small shank Date=4/25/2007 Time=7:28:20 AM
            T1A0B0 THEO X 0.0000 Y -0.2244 Z 3.8906 D 0.1181
            T1A0B0 MEAS X 0.0032 Y -0.2261 Z 3.8997 D 0.0589 StdDev 0.0000
            T1A0B0 SHANKI 0.000571 J-0.004425 K 0.999990
            Measured probe diameter error exceeds the limits.
            T1A0B0
            It gives me an error message after measuring the ball?? Out of tolerance.
            It seems the diameter is 1/2 what it should be.??
              OK, Got It
              I forgot to change the Diameter in the hotspot line.
              I think I got it now.
              Thanks for the help.
              Mike
              begintip
              ribcount 10
              color 142 142 142
              color 255 0 0
              endtip
              color 142 142 142
              begintip
              ribcount 10
              color 142 142 142
              color 255 0 0
              hotspot 0 0 -13 0 0 1 1.5 4 shank
              endtip
              color 142 142 142
