I am in the auto-circle window. I am trying to drag my hits around on an OD circle. I can drag around the first hit and change the start end angles just fine. If I go to drag around my other hits to avoid a flat on the diameter sometimes they drag fine, other times they 'collapse' in toward the OD and end up with a funny vector. Anyone know why this is?
Dragged Hits 'Collapsing'
I have had it happen to me. I have found that using 3D rotate and zoom so that my graphics of the feature are large and "square" helps to prevent this. Make sure you click on the hit "arrow" and not the path "line" in between.
It is touchy, but if you blow it up and are careful you can usually avoid the collapse. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Originally posted by tking View PostWes,
I just read this, thanks! Nice clue. No training here so now I'm one clue less clueless! What did I just say.........
TKXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by Wes Cisco View PostI have had it happen to me. I have found that using 3D rotate and zoom so that my graphics of the feature are large and "square" helps to prevent this. Make sure you click on the hit "arrow" and not the path "line" in between.
What I did was once I got them all placed, I tabbed through the feature in the edit window and changed the j vector value (circle vector 0,1,0) to zero. That seems to have taken care of it nicely.
Good luck,
It is certainly the relationship between the graphic view and the part orientation. Use the squaring button in the auto-feature box, and zoom window to resolve this.
PC-Dmis has the best graphical based programming interfaces I've seen, the only other program that comes close is verisurf. Using the graphic interface takes some hand eye conditioning, you may wish to practice 1-2 hours a day on a video game like tetris to improve your skills.
GLast edited by Cumofo; 07-12-2007, 07:51 PM.sigpic
Originally posted by Cumofo View PostPC-Dmis has the best graphical based programming interfaces I've seen, the only other program that comes close is verisurf. Using the graphic interface takes some hand eye conditioning, you may wish to practice 1-2 hours a day on a video game like tetris to improve your skills.
[ATTACH]1291[/ATTACH]
G
My *** has been dragging
Originally posted by rangerboat72 View PostMy *** has been dragging lately but I have not had any problems with it collapsing.
I think this *** may collapse soon.
http://mud.mm-a5.yimg.com/image/3342053401sigpic
I was told by an instructor that that functionality was not working correctly in 3.7MR3 and that it was fixed in 4.0. Well, in 4.1 I have found that when dragging hits, it looks fine. But when you run the feature, the depth goes about 4 x the typed depth. This apparently is not working in 4.1 either. We are staying away from it here. FYIsigpic GDTPS - 0584
I'm running 3.7mr3 by the way. Anybody else know a workaround?** "Well, ain't this place a geographical oddity. Two weeks from everywhere!"~ Ulysses Everett McGill **
by mr500wrote the program but I don't like the way the probe is hitting one of the ID's. The hits are way too close. How do I change that with out screwing something...
04-09-2008, 08:58 PM -
by Clay_ManGood morning all
I have a bore dia. of 16.805 mm +/- 0.025mm, I am checking on the cmm I use 9 hits, to report dia.. The customer I measure...-
03-08-2006, 09:45 AM -
by pnivenPHP Code:
[HTML]Help File[/HTML]
Without using CAD Data for an Auto Circle
To generate the circle without the use of CAD data:
Take three hits on
05-20-2008, 11:34 AM -
by giantslayerHi,
I am working on a program that has a few smaller radii that I am trying to measure using auto feature. I am placing the auto circle...-
08-12-2015, 09:04 AM -
by JR VILLAim having a problem moving my hits in the graphics view when I chose a hole the sample hits are there but I cant manipulate them if I change them in...
10-02-2013, 04:00 PM -
