Hi,
When simulating a program to check out any collisions. I was always told to generate the path lines, animate the path, then run collision detection.
However, someone has now told me that to check out collision detection you only need to generate the path lines then run collision detection. Is this right or should you still run the animate path command in between.
Thanks
Thanks
