This last week we have found a somewhat concerning bit of data and hope to see some clarity from this. On site SMEs are looking into to tomorrow hopefully but I figured I would ask here as well. We are attempting to measure a quite short taper on a part, no CAD I am able to share sorry. Here is a breakdown of the issues we are having.
Taper in question is approx. .27" long and 1.6250" at the smallest point with a 10* angle. Tolerance is +0/-0*8'48". This issue was noticed purely by chance as the original programmer was using 12hitsx3rows, and I had to write a quick program to measure an incomplete part that used 12hitsx6rows. His program showed the angle in excess of 10* and mine was less than 10*, with a deviation between the 2 of almost a full degree with the part having not moved at all between runs. Profile scan up the taper coincides with my data, but through a set of tests using all variations we noticed that 12x5 was the only one that showed in on the specific part tested, and that coincides with the profile scan data. I am inclined to believe the profile scan data but the data makes no sense and contradicts what the senior programmers advise for the 2014 program we are on presently.
This data makes no sense as the data put into a graph shows the deviations of 3, 4, 6, 7, and 8 rows is almost identical vs the 5 row and profile scans matching.
Any insight would be greatly appreciated as myself, and the senior programmer at this facility are at a complete loss. I am going to confirm this taper on a form tracer today and hopefully get some idea of the actual taper to compare it to.
