Gap on Linear-Closed Scan
  • Gap on Linear-Closed Scan
    Hello, I scanned a small tool once but this gap located between the start and end points is bothering me. The part is pretty small, around 15mm long. I had scanned another part some time ago which was a little longer and apparently the gap is also there. I just want to know if it's normal or if it's something I can somehow make disappear? If so, can anybody help me with that?
    Thanks.
    Can you post the code with showing all parameters turned on?
    7107 Global Classic TP20
    2019R1 SP1 CAD++
      It's dependent on your boundary type.
      Try a cylinder boundary with 3 crossings and a radius slightly bigger than your probe radius.
        How can you have endpoints on a Linear-Closed scan?
        As for the gap - are you using DEFINED? If so, the scanned points may be ignored if the part deviates too much (scanning in the air).
          it actually happens a lot, even on "no-cad", "no-find", "relearn" closed scans. I see it a lot on smaller holes, to the point that I change the crossings to 3 so that it will go around 1.5 times.
