Viewing dimensions
  • Viewing dimensions
    Is there a way that I can visually see the dimensions in the graphic display window?
    right click on the feature in the graphic display and select Create Dim Info Box... others will know better about settings though but that's a start
      you can also turn GRAPH to ON within the dimension output, then increase the MULTI (multiplier for the error value) until you get a deviation arrow that's visible
      • fruitlessapple
        fruitlessapple commented
        where do I go to turn the GRAPH on?
      • fruitlessapple
        NM I got it. Worked! Thanks!
