TR_ FG150.X1xT Error
  • TR_ FG150.X1xT Error
    Getting TR_ FG150.X1xT Error intermittently when move in "Y"
    Alpha Image 25-50-15 - Lietz controller - V3.7 MR-2 - XP SP2.
    Cleaned with denatured alcohol a number of times.
    "Y" move may be manual or programmed.
    Will get error, walk a way for a while, come back, find problem went away only to recur again later.
    Any Ideas???
    STATUS Label Error Message
    X_IxT : ERROR X_IxT,S%1,TR_FG150,X IxT Error
    Y_IxT : ERROR Y_IxT,S%1,TR_FG151,Y IxT Error
    Z_IxT : ERROR Z_IxT,S%1,TR_FG152,Z IxT Error
    W_IxT : ERROR W_IxT,S%1,TR_FG153,W IxT Error
    A_IxT : ERROR A_IxT,S%1,TR_FG154,A IxT Error
    B_IxT : ERROR B_IxT,S%1,TR_FG155,B IxT Error
    A circuit on the servodriver has detected saturation (i.e. peak level) of the motor current for a time longer than allowed. It may be due to a motor overload owing to obstacles to motion (collision,friction) or a motor failure or a failure of the mechanical motion system or of the servodriver.
    Clean Air Pipelines , Air Pads and check the belts.
    HTH
    Saliha
    Either seem as you are or be as you seem.M.J.Rumi
      Check for any obsruction of the drive system like Shaliha said. If it happens in the same location each time it could be a sticky spot on a bearing surface or a belt. If you have recently removed any shrouds from the machine and reinstalled them check for rubbing.
        For future reference:
        Problem turned out to be an air bearing,
        was replaced by B & S
          We had this error message when trying to home the machine on start up. Found that the magnetic that is supposed to be just below the Y scale in the front of the machine was out of location. There was a mark on the granite weighs where it is supposed to adhere to with double back tape. Put Magnetic back to that location and the machine homed properly.
