Iterative alignment question
  • Iterative alignment question
    I am trying to create an alignment to an airfoil using a six point nest. I have been supplied with the XYZijk of all six points. I can reputably locate this part in a fixture on the CMM.
    I set the fixture up and save the alignment for recall into my program.
    I start my program out by recalling external alignment. I know where the part coordinate system should be relative to the fixture, so I make the shift for external alignment.
    I go to DCC mode and do a my six AutoVector points.
    I'm not sure if an iterative alignment is the correct way to go about aligning to these six points. After measuring the six points, I go to Iterative ALignment.
    I pick the three points that are on the face of the airfoil. Then two points on the leading edge of airfoil, and one point on a platform for Z.
    I use a fixture tolerance of .0002 (inches). Measure ALL always max iterations=6. When I run the program it cycles through the six points 2 times and comes up with a window (see below ) saying there are deviations up to .023inch. Not sure why it would not rehit those points again. I figured I would rehit those 6 points after this alignment and they actually showed on devations up to .0015.
    I am a PCDMIS noob ( 3 months ).. Hope I made sense. Thanks
    PART NAME  : mddt5612
    REV NUMBER :
    SER NUMBER :
    STATS COUNT : 1
    STARTUP    =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES
                ALIGNMENT/END
                MODE/MANUAL
                TEMPCOMP/METHOD = AUTOMATIC,MATERIAL = Zerodur; Nexcera,CTE=0
                  ,SET WARNING LIMIT = TRUE,MINIMUM = 18,MAXIMUM = 22
                  ,PART SENSOR NUM=DEFAULT,X SCALE= 20,Y SCALE= 20,Z SCALE= 20,PART TEMP=25.1017
                LOADPROBE/STAR_2MM
                TIP/TIP4, SHANKIJK=-0.5378, 0.8431, 0, ANGLE=-90
                RECALL/ALIGNMENT,EXTERNAL,LEFT_MDD
    A1         =ALIGNMENT/START,RECALL:LEFT_MDD,LIST=YES
                  ALIGNMENT/TRANS_OFFSET,XAXIS,-0.658
                  ALIGNMENT/TRANS_OFFSET,YAXIS,-0.2
                  ALIGNMENT/TRANS_OFFSET,ZAXIS,-5.4279
                ALIGNMENT/END
    A2         =ALIGNMENT/START,RECALL:A1,LIST=YES
                  ALIGNMENT/ROTATE_OFFSET,-32.5333,ABOUT,ZPLUS
                ALIGNMENT/END
                MODE/DCC
    PNT1B      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                THEO/<0.1945,0.1533,6.732>,<-0.3626097,0.8887237,-0.2805075>
                ACTL/<0.2255,0.1463,6.7528>,<-0.3849318,0.8792587,-0.2805917>
                TARG/<0.1945,0.1533,6.732>,<-0.3626097,0.8887237,-0.2805075>
                SNAP=NO
                SHOW FEATURE PARAMETERS=NO
                SHOW CONTACT PARAMETERS=NO
    PNT2B      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                THEO/<-0.1728,-0.1351,6.732>,<-0.8336443,0.5463291,0.0810043>
                ACTL/<-0.1353,-0.1502,6.7577>,<-0.8446707,0.528159,0.0870598>
                TARG/<-0.1728,-0.1351,6.732>,<-0.8336443,0.5463291,0.0810043>
                SNAP=NO
    PNT3B      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                THEO/<-0.0343,0.0526,7.245>,<-0.7347837,0.675285,-0.0638986>
                ACTL/<0.0041,0.0428,7.2685>,<-0.7501282,0.6586222,-0.0593676>
                TARG/<-0.0343,0.0526,7.245>,<-0.7347837,0.675285,-0.0638986>
                SNAP=NO
    PNT5B      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                THEO/<-0.1962,-0.1852,6.732>,<-0.7339043,-0.678704,0.0273002>
                ACTL/<-0.1576,-0.2008,6.7582>,<-0.7184164,-0.6946013,0.0375084>
                TARG/<-0.1962,-0.1852,6.732>,<-0.7339043,-0.678704,0.0273002>
                SNAP=NO
    PNT6B      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                THEO/<-0.1791,-0.184,7.245>,<-0.6461089,-0.7629105,0.0226003>
                ACTL/<-0.1354,-0.1969,7.2709>,<-0.6288323,-0.7768705,0.0322826>
                TARG/<-0.1791,-0.184,7.245>,<-0.6461089,-0.7629105,0.0226003>
                SNAP=NO
    PNT7B      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                THEO/<-0.216,-0.069,6.6161>,<-0.0137005,-0.0119004,0.9998353>
                ACTL/<-0.1811,-0.0856,6.642>,<-0.003506,-0.0077766,0.9999636>
                TARG/<-0.216,-0.069,6.6161>,<-0.0137005,-0.0119004,0.9998353>
                SNAP=NO
    A5         =ALIGNMENT/START,RECALL:A2,LIST=YES
                  ALIGNMENT/ITERATE
                    PNT TARGET RAD=0.07,START LABEL=,FIXTURE TOL=0.0002,ERROR LABEL=
                    MEAS ALL FEAT=ALWAYS,MAX ITERATIONS=10,LEVEL AXIS=XAXIS,ROTATE AXIS=YAXIS,ORIGIN AXIS=ZAXIS
                  LEVEL=PNT1B,PNT2B,PNT3B,,
                  ROTATE=PNT5B,PNT6B,,
                  ORIGIN=PNT7B,,
                ALIGNMENT/END
    PNT1C      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                ACTL/<0.1945,0.1531,6.7321>,<-0.3626097,0.8887237,-0.2805075>
                SNAP=NO
    PNT2C      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                ACTL/<-0.1738,-0.1354,6.7313>,<-0.8336443,0.5463291,0.0810043>
                SNAP=NO
    PNT3C      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                ACTL/<-0.0355,0.0529,7.244>,<-0.7347837,0.675285,-0.0638986>
                SNAP=NO
    PNT5C      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                ACTL/<-0.1975,-0.1859,6.7316>,<-0.7339043,-0.678704,0.0273002>
                SNAP=NO
    PNT6C      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                ACTL/<-0.1804,-0.1848,7.2448>,<-0.6461089,-0.7629105,0.0226003>
                SNAP=NO
    PNT7C      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                ACTL/<-0.2163,-0.0691,6.6161>,<-0.0137005,-0.0119004,0.9998353>
                SNAP=NO
    DIM LOC1= LOCATION OF POINT PNT1C  UNITS=IN ,$
    GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
    AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL
    X       0.1945     0.0020     0.0020     0.1945     0.0000     0.0000 ----#----
    Y       0.1533     0.0020     0.0020     0.1531    -0.0002     0.0000 ----#----
    Z       6.7320     0.0020     0.0020     6.7321     0.0001     0.0000 ----#----
    T       0.0000     0.0020     0.0020    -0.0002    -0.0002     0.0000 ----#----
    END OF DIMENSION LOC1
    DIM LOC2= LOCATION OF POINT PNT2C  UNITS=IN ,$
    X      -0.1728     0.0020     0.0020    -0.1738    -0.0010     0.0000 --#------
    Y      -0.1351     0.0020     0.0020    -0.1354    -0.0003     0.0000 ---#-----
    Z       6.7320     0.0020     0.0020     6.7313    -0.0007     0.0000 --#------
    T       0.0000     0.0020     0.0020     0.0006     0.0006     0.0000 -----#---
    END OF DIMENSION LOC2
    DIM LOC3= LOCATION OF POINT PNT3C  UNITS=IN ,$
    X      -0.0343     0.0020     0.0020    -0.0355    -0.0012     0.0000 -#-------
    Y       0.0526     0.0020     0.0020     0.0529     0.0003     0.0000 -----#---
    Z       7.2450     0.0020     0.0020     7.2440    -0.0010     0.0000 --#------
    T       0.0000     0.0020     0.0020     0.0011     0.0011     0.0000 -------#-
    END OF DIMENSION LOC3
    DIM LOC4= LOCATION OF POINT PNT5C  UNITS=IN ,$
    X      -0.1962     0.0020     0.0020    -0.1975    -0.0013     0.0000 -#-------
    Y      -0.1852     0.0020     0.0020    -0.1859    -0.0007     0.0000 --#------
    Z       6.7320     0.0020     0.0020     6.7316    -0.0004     0.0000 ---#-----
    T       0.0000     0.0020     0.0020     0.0015     0.0015     0.0000 -------#-
    END OF DIMENSION LOC4
    DIM LOC5= LOCATION OF POINT PNT6C  UNITS=IN ,$
    X      -0.1791     0.0020     0.0020    -0.1804    -0.0013     0.0000 -#-------
    Y      -0.1840     0.0020     0.0020    -0.1848    -0.0008     0.0000 --#------
    Z       7.2450     0.0020     0.0020     7.2448    -0.0002     0.0000 ----#----
    END OF DIMENSION LOC5
    PCDMIS 2019 R1
    GLOBAL 5x5
    I think it exceeded your TOL by so far it knows it cannot solve ? Increase the TOL and run it and see if it make sit thru.
      What's your "Point Target Radius"? That's what will decide if the iteration should stop or retry. The "Fixture Tolerance" doesn't come into play until you have more than six points (if I have understood it correctly).
      • Marken199
        Marken199 commented
        The point target tolerance is .070. Maybe the initial points are out that much. I will increase the target tolerance and try again later today. Thanks for the help Anders and Schlag.
      • AndersI
        AndersI commented
        Actually, you should probably lower it, to get more iterations. The largest dev in your picture is 0.023, so with a 0.07 tolerance PC-DMIS will think that's "good enough". But mainly, listen to Matthew - he knows those things!
      • Matthew D. Hoedeman
        Matthew D. Hoedeman commented
        Well, the ONLY time I have ever had Pcdmis run through the iterative more than twice is when the part was such a POS that my standard POINT TARGET RADIUS of 0.5mm (0.020") wasn't big enough for the crappy part. I use 0.5mm and 0.05mm (fixture tolerance) standard forever. I was told that if you used a ZERO fixture tolerance that it would run through the alignment as many times as you had for MAX ITERATIONS. This is NOT true. I've used ZERO fixture tolerance and still only had it go through twice. I use iterative alignments on sheet metal part holding fixtures, so, vectors and nominals not "square" to the world, and still it will only go through twice (measure all always). ONLY time it did more than 2 was when the target radius wasn't big enough for a garbage part. Keep in mind when I do this on fixtures, I do a minimum of 3 hits per net pad (datum simulator, whatever you want to call them), and there is usually at least 4, but I've had up to 27 net pads for a part (yes, that was insane!). No matter the fixture tolerance, 2 times through. And yes, there is ALWAYS deviation if using more than the minimum features.
      a 6 hit iterative alignment should show zero deviation for the 6 hits after it solves. 3X, 2Y, 1Z, all should show zero deviation.
        Looking at your features, your VECTORS are wrong for the iterative action you want to do with them.
        1B is mostly Y
        2B is mostly X
        3B is mostly X
        5B is mostly X
        6B is mostly Y
        7B is mostly Z
        So you should be using 2B, 3B, 5B for 'level'. 1B & 6B for rotate, 7B for origin
        And those vectors are way too far (IMO) from any axis to use for an iterative alignment. Close to 45 degrees? BAD choice for an iterative alignment feature.
        • Marken199
          Marken199 commented
          Thanks Mattew. That's the problem.... it was about 32 degrees. I rotated 32 degrees to square up the coordinate system and recalculated vector touches, then did iterative alignment. It resolved perfectly... I then rotated -32 degrees from there. All good. Thanks!
