Hello Everyone
I have a question regarding composite profile. I have attached a rough sketch for reference. Can someone please explain how to properly dimension the lower segment of this composite profile. I am using legacy dimensioning so I would like to see the correct method based on legacy. This is a stamped part with 4 arcs (trim edges) that need to be controlled to the main datums and also as a feature set. A pipe will weld to these 4 edges. I have added edge points to all 4 arcs and have dimensioned the T values of each point relative to ABC. For the lower segment I have created a 2D best fit alignment in the Y+ workplane allowing translation along the X and Z axis. Under this alignment I dimension the edge points to check the lower segment. Should this be a 3D best fit?? Please ignore the datum modifiers for this discussion.My main focus is creating the correct best fit alignment to check the lower segment.
Thanks
Scott
Thanks
Scott
