I'm brand new to using PC-DMIS. I feel I've made good progress on learning basics, and being able to fix mistakes in programs (I run into errors in programs alot here...). I cant always get the programmer here to fix them in a timely manner so I usually just explore here and or the help files till I find a fix. However, I've run into problems that are beyond my knowledge and this here is one of the more common problems I've had that I cant figure out.
So, this is what happens. I pull up program, calibrate all used tips and angles, start program take manual alignment points (in this program its 3 pln points 'z', 3 pln points 'y', and 3 pln points 'x'). Then when program goes into DCC it seems the machine thinks the part has shifted anywhere from .5-2 inches x negative... Because of this I'm not able to run the program at all.
help would be greatly appreciated! Though as I stated before i'm still fairly new to it all.
