Temperature error
  • Temperature error
    I got this temperature on my machine when I went to start. How can I fix this? Thanks for any help. Here is the message.
    In your block of code that handles temp comp... UNCHECK the box that say "set warning limits". That will get rid of the warning.
    The above said.. the software is trying to tell you that it is sensing that the motors that are too hot/cold. If this is true, your machine might be malfunctioning & giving you bad data. Be careful!
    • louisd
      louisd commented
      or most commonly, your stringently defined environmental constraint is outside of the defined limits.
      I don't think the proximity of the readheads or scale. would be affected much by a hot motor. they mount them with phenolic spacers/flanges I presume to insulate heat.
    thanks for the information.
