2019R2 Summary Mode While running program
  • 2019R2 Summary Mode While running program
    I have installed PcDmis 2019R2 on 4 of our machines. Now the edit window goes into summary mode while running a program. I want it to stay in command mode. We just installed a new machine with 2019R2 and it stays in command mode. Can someone tell me where I can change this setting?
    Start a program with some manual measurement. Instead of measuring you adjust everything until it looks as you want it. Stop the program *and save it*. You have now adjusted the secret special window layout used when executing.
    Or, F5, General tab, locate "Use Program Layout for Execution" and make sure it is checked.
    • gszpot
      gszpot commented
      Thanks AndersI. I hit F5 and checked the "Use Program Layout for Execution"
    I have a different question when working in V19R2, I prefer working in summary mode. However, it does not allow the drop down folder when looking at a feature to see the theo / actual / target as in previous PCDIMS versions. I have to go into command mode to view those. Is there a setting for this?
    • johnP
      New job... new problems
      by johnP
      I am having a problem with 1 machine with 2010 loaded. While programming and executing, the edit window changes from command mode to summary mode by itself...
      10-13-2011, 06:01 PM
    • Carlos Lumbre
      Command Mode
      by Carlos Lumbre
      Some body can help me , my program in Command Mode when start to run(execute) change to Summary Mode. I try go to View/Command Mode but return to summary...
      05-10-2019, 07:23 AM
    • Jay Curtis
      Desktop Configuration
      by Jay Curtis
      On my desktop configuration, I have the edit window in "command mode". The problem I'm having is when I press "control Q" to execute...
      10-29-2020, 06:32 AM
    • mtjohn
      Edit window change
      by mtjohn
      Just installed PC-DMIS 2017 R2. The edit window changes from command mode to summary mode when executing a program.
      05-08-2018, 08:25 AM
    • bsteele
      Summary / Command mode
      by bsteele
      Looking for some help here. Since we updated to 2017 R2, When executing programs, the edit window switches to Summary mode and will not let us change...
      05-16-2018, 10:32 AM
