DEVANG on report
  • DEVANG on report
    I'm doing a true position output and for some reason, in the report it shows a column called "DEVANG" between "DEV" and "OUTTOL". I don't know how or why it's there, but how can I remove it from the report to avoid any confusion?
    angle deviation, it is tell you where in the 'circle' of tolerance it is located.
      Hit F10 and uncheck Dev angle in your output parameter settings.
        Thanks!
          interesting.
          when i changed "show nominals" to "yes" in the first of 10 tp characteristics it also went away
          for all 10...
            and "dev ang" was already unchecked @ f10
            odd...
              There's a FORMAT command near the top of the program Edit (F9) that and switch it off there.
              Applications Engineer
              Hexagon UK
