How to make report with color map after scan
From the file menu Insert | Pointcloud | Surface Colormap
This will get you the colors based on the amount of tolerance used. The individual readings would need to have points created from the pointcloud that are then tolerance. Put the cursor on the pointcloud command and hit F9 to bring up the dialogue window. Click where you want a point and click create point on the pop up window. Repeat for all the points you want. Use CAD only Landscape report style. Right click on each label to enable editing and you can drag them to where you want.PC-DMIS 2016.0 SP8
Jeff
by mitkosHello to you all.
I have 2 CMM and I noticed different scan display on my 2 computers. On one PC my scans are in color, showing deviations...-
06-01-2021, 12:55 AM -
by Tomi530iGood morning all
I have a nooby question.
When I'm using auto feature I can change the measurement strategies to Adaptive Scan...-
02-08-2016, 06:19 AM -
by zeljkoHello,
I tried to insert scan and when I executed program, machine doesn't do scan, but touching? Also, when I add auto plane feature with...-
05-10-2018, 02:51 PM -
by Max TastyI'm in the process of teaching myself scanning with PC-DMIS. I'l probably have more questions along the way.
About half the time my scan...-
07-26-2018, 06:31 PM -
by cfranklinI wondering how do you use the scan function using version 3.5????
11-10-2008, 01:18 PM -
