How to change distance between points in auto plane without changing spacer value?
Auto plane points modification
In the graphics window, you can grab the points and drag them about. The first point, the touch line itself changes color, every other point the move line changes color.
In command mode, the last line of the feature is "Show Hits," toggle to Yes. Edit the X, Y and Z values as you see fit.
In Summary mode, expand the tree for the feature, last sub-tree is "Hits," expand that and each hit you want to adjust, change the X, Y and Z as you see fit.
- Likes 1
by bmdfmI am trying to create an auto plane, but need to remove a point without the feature recalculating even spacing. I want the points in exactly the same...
09-25-2020, 10:46 PM -
by CarfinBear72Looking for a bit of help,
Trying to use the auto plane function for the first time. I'm taking a plane on a thin ring, so want to be able...-
08-08-2017, 10:19 AM -
by jleondWhen I measure an auto plane with actual thickness selected (2mm) the actual meas is wrong, using a constructed plane from vector points (with 2mm actual...
08-29-2008, 11:09 PM -
by DMIS_guyWhen creating an auto plane, The spacer sets the distance from center but say i want to run two rows. Is it possible to have the first row at the set...
10-10-2022, 09:23 AM -
by Samsdadmatthow do i determine the diameter of a radial auto plane? i'm not working from a CAD model
05-24-2016, 05:15 AM -
