Hello I'm trying to measure a part running a program that was sent to me. It was running ok but then when it went to measure one point it said it said "no probing within probe limit" but it does touch the part and it does it on the right place. Is it an error?
No Probing Within Probe Limit (but it is within!)
Originally posted by Hirxm View PostHello I'm trying to measure a part running a program that was sent to me. It was running ok but then when it went to measure one point it said it said "no probing within probe limit" but it does touch the part and it does it on the right place. Is it an error?3.7mr3CAD++ / 2011mr1CAD++/2012mr1CAD++/QUINDOS7
- Likes 1
Ok I changed the Check distance just as louisd and hi-tech redneck said and it worked. Thanks. Can anyone explain to me what the check distance is?
not 100% sure, but I wanna say it's a percentage before and after Theo location the machine will "Look" for a hit
CHECK is really only useful when the Pcdmis default don't work. For example, to stop the machine from traveling as far when it misses the part, or if there is an interference issue under a hole (for find hole). I've only used it a couple times in 30 years. WITHOUT a CHECK command in the program, Pcdmis will travel TWICE as far as the prehit value past the THEO values for a touch.
check is how much further it will go past the theoretical hit to find the surface. If it does not find the part within the check distance you get the alarm you described. Call me old fashioned but I say screw pcdmis defaults and always have them in my program
by zach19564When im running my program it will get about half way done and then i will get an error message "TR_PR01, no probeing within probing limit"....
02-14-2013, 02:32 PM -
by GreglTR_PBR01 No Probing within probe limit.
Global Image 3.7mr3
Just started getting this friday in a program that we have been...-
03-13-2007, 12:01 PM -
by ImpelDanHaving an issue that I have never seen before with a machine. (PH10MQ, PH20-NI)
The probe will contact the surface, audible beep will sound, and...-
12-21-2017, 04:25 PM -
by 57shrimpOn version 2013 mr1 I got the above error even though the probe was physically hitting the part as indicated by to probe light going off.
01-24-2017, 07:30 PM -
by Stephen1055I am running into this error a lot today.
I am simply attempting to measure an OD with a 7 point circle.
It gives me the...-
05-11-2015, 02:28 PM -
