I'm using the CMM to check a pretty basic part, essentially a rectangle with 8 holes placed through it. I wrote a program and proceeded to start checking parts and a common theme occurred (the part is near symmetrical) when I measured the top side everything would measure in spec. When I measured the part flipped over all distances would measure in spec, but multiple hole position callouts would show as rejected saying they are outtol/the icon showing red.
I assumed somehow I was missing something and rechecked my datum references and call outs(everything checked out). The part is pretty thin (.090") so I was measuring the holes as circles......I had our CNC operator make me a thicker part so I could measure the holes as cylinders......same result. I added additional information to check; each individual hole distance from the other holes, distance to all 4 edges, rechecked the diameter, all clearly in spec. I double checked these measurements with a vision system, everything passed. Everything seems to be 100% fine, but the program continues to tell me 1 side is in spec, when I flip it and measure the other side multiple holes are outtol in the position callout. Any idea what could be causing this? II'm just kind of stumped , any help would be appreciated.
