I need to check parallelism of a slot at the end of disk and getting different value for different length of line generated as center line
of slot.
Any idea how PC-DMIS calculates parallelism’s values.
Also,
Need help for the following,
Requirement: Slot C/L to be parallel within 0.004 IN./IN.
Description:
I am generating parallelism of these two lines with tolerance of 0.014 (3.4625 x 0.004) not sure if i'm interpreting this right
I got result of 0.0002 but the part is showing nonconforming when costumer is inspecting the same part.
Dovetail slot length as per drawing is 0.226
Length of line generated for slot is 0.0704 and part C/L is 3.3913 as per program
Thanks in advance.
of slot.
Also,
Description:
Thanks in advance.
STARTUP =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES ALIGNMENT/END MODE/MANUAL CHECK/0.1,1 MOVESPEED/ 100 SCANSPEED/100 FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,DEV,OUTTOL, , LOADPROBE/PRB#27 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 MODE/DCC PNT1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<0,-0.0009,-0.433>,<0.0001697,-1,0> ACTL/<0,-0.0009,-0.433>,<0.0001697,-1,0> TARG/<0,-0.0009,-0.433>,<0.0001697,-1,0> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=BOTH,DISTANCE=0.3937 SHOW HITS=NO PNT2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<0.0006,-3.3922,-0.433>,<0.0001697,-1,0> ACTL/<0.0006,-3.3922,-0.433>,<0.0001697,-1,0> TARG/<0.0006,-3.3922,-0.433>,<0.0001697,-1,0> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=BOTH,DISTANCE=0.3937 SHOW HITS=NO PART_CENTER_LIN=FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,-0.0009,-0.433>,<0.0001769,-1,0> ACTL/<0,-0.0009,-0.433>,<0.0001769,-1,0> CONSTR/LINE,BF,3D,PNT1,PNT2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 PNT_S1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<0,-3.3256,-0.25>,<0,0,1> ACTL/<0,-3.3256,-0.25>,<0,0,1> TARG/<0,-3.3256,-0.25>,<0,0,1> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=BOTH,DISTANCE=0.3937 SHOW HITS=NO PNT_S2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<0.0002,-3.396,-0.25>,<0.0000684,0.0000105,1> ACTL/<0.0002,-3.396,-0.25>,<0.0000684,0.0000105,1> TARG/<0.0002,-3.396,-0.25>,<0.0000684,0.0000105,1> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=BOTH,DISTANCE=0.3937 SHOW HITS=NO SLOT_CENTER_LIN=FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,-3.3256,-0.25>,<0.0028409,-0.999996,0> ACTL/<0,-3.3256,-0.25>,<0.0028409,-0.999996,0> CONSTR/LINE,BF,3D,PNT_S1,PNT_S2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 DIM PARL1= PARALLELISM OF LINE SLOT_CENTER_LIN,RFS TO LINE PART_CENTER_LIN,RFS EXTENDLENGTH=0.0000 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL M 0.0000 0.0140 0.0000 0.0002 0.0002 0.0000 #----
