I tried this by creating generic features with the circles to make them the same size. Didn't work since the construct cylinder would not see the generic feature as a circle even though it IS a generic 'circle'. Any other way to trick PC-Dmis into accepting this? When I try to just created a cylinder with the circles it throws the center point off big time.Thanks!
Create Cylinder from different size circles?
Not really sure exactly what you are trying to do, but if you are looking for the vector between center points, construct a 3D line. Then take the IJK from the line and insert it into a generic cylinder with whatever diameter you want.153010 Global Advantage w/ LSPX1H_T Analog Probe
7107 Global Classic TP20
2019R1 SP1 CAD++
If you want to construct two separate size diameters together, geometrically speaking that is a cone. If you click to construct a cone, PC DMIS can handle that construction all day.
If you want the AXIS that the two circles share, simply construct a line from the center-point of one circle to the other.SF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
by grandpaal56I'M LOOKING FOR A LITTLE HELP. I MEASURED TWO CIRCLES INSIDE A CYLINDER 50.0mm APART. IS THERE A CONSTRUCTED POINT OPTION WHERE I CAN CONSTRUCT A POINT...
03-11-2009, 04:37 PM -
by dragonbladeHi
I have attached a picture of a part that I hope can be seen.
the small OD on the left and right sides are dat -A-'s. I measure...-
02-14-2009, 12:45 PM -
by Ed the RedHopefully someone can help this lame a$$ newb, using V4.2 trying to construct a cylinder from two different diameter bores (measured as circles) in...
10-21-2011, 06:03 AM -
by Big RedGuru allert! Please help settle our conflict...
Is it better, worst or the same to use a Constructed Line or a Cylinder?
03-01-2007, 09:03 AM -
by Slug DawsonI have a CCC problem. The part is a half circle with a flat running lengthwise along the middle. The part is flared and then has another round section...
04-14-2010, 02:01 PM -
