I am using pcdmis 2019 r2 and every time it crashes (seemed like every 5 minutes today) it resets my default printer to pcdmis convertor 50 and my report will not print out until I reset default printer. What do I need pcdmis convertor 50 for and is there any way to stop it resetting my default printer.
pcdmis converter50
Originally posted by gnichols73 View PostI am using pcdmis 2019 r2 and every time it crashes (seemed like every 5 minutes today) it resets my default printer to pcdmis convertor 50 and my report will not print out until I reset default printer. What do I need pcdmis convertor 50 for and is there any way to stop it resetting my default printer.
Windows 10 has the nasty habit of setting the latest installed printer driver as the default driver. Not always, but it does happen. I don't know what the pre-conditions are for this to happen, but I've seen it many times. I don't think it has anything to do with PC-DMIS.AndersI
- Likes 1
Nothing to do with PC-DMIS.
In Windows, Start button and then Settings . Go to Devices > Printers & scanners, uncheck the box that says "Let Windows manage my default printer".Systems Integrator
- Likes 1
this box is not checked. the only reason I thought it had to do with PC-DMIS is it only resets after PC-DMIS crashes. the morning I started this PC-DMIS was crashing like every 5 minutes. was not a productive morning lol
ok one more question. if do not want to save pdf's of the reports would I need converter 50?
I print my reports to PDF and if the operators want a paper copy I have them print from adobe. If I set the paper printer as the default printer from...
05-05-2010, 09:59 AM -
by TowndoggWhy do I have to select the printer I want to send to every morning when I boot up the CMM? I can run a program (I will call this program "A"...
11-13-2017, 09:25 AM -
by TestedAt the end of the program when it comes time to print some how the program is switching from my default printer to the "PC DMIS 250 CONVERTER"...
09-19-2008, 12:46 PM -
by norkamus
It is. Yes it is. For expletive's sake, yes it is. I have been using it for years. What happened? All I'd like to do is output my report as .PDF,...-
06-08-2016, 09:22 AM -
by MatttFlorerWhere does PC-DMIS select the 50 Converter at? Can I change that to CutePDF?
Thanks,-
07-09-2019, 01:10 PM -
