I inspected a part using individual points all over it. Now I have a CAD model with nominal data. It is possible to compare the points taken to the CAD? All points are auto-vector points and the Theo, actl, and targ all match (no deviation between Theo and actl) I didn't have CAD at the time. Thanks.
Compare to CAD after measurement
There's many ways to skin this cat.
Here's what I would do. Open new routine.
Load CAD. Make sure CAD coordinates roughly resemble how the part will sit on the granite (F5 Part/machine setup get it so CAD axis match how it would sit on granite).
Copy all your setup and initial inputs from the existing routine.
OFFLINE in Program Mode (CTL+F4 if i recall correctly) click your manual feature alignment points on each feature:
3 point plane, press END on keyboard.
2 point line. press END on keyboard, and
1 point edge origin, press END on keyboard.
Align. (CLT+ALT+A)
add Mode/DCC and clearplane movepoint as you so desire...
Paste all your DCC code from the other routine into this new one.
You should be set.
- Likes 1
If you edit the nominal values of the manual alignment features to match the CAD values for the same features then that will "marry" the CAD to the program. A quick way to do this is go to an alignment in the program that matches the alignment of the CAD model. Then use Operation | Graphic Display Window | CAD Equals PART. This will change the nominal values of the manual alignment features for you.
Alternatively you can do it like louisd said above. Either way you will then have a CAD matched to your program.
Now do inspect those measured points back to the CAD, use Edit | Graphic Display Window | Point Nominal Deviation. This will compare the points to the model and give you the opportunity to move the points. The interesting thing is that when it moves the nominal values of the points, it doesn't change the measured values. This way you can check the points you already measured.
Last but certainly not least. DO THIS WITH A COPY. Always make a copy before doing any kind of edits like this. PC-DMIS can do weird things, even to seasoned programmers doing something that they have done many times. Have fun!PC-DMIS 2016.0 SP8
Jeff
- Likes 1
We are having trouble aligning cad models to the part, can anyone point us in the right direction in simple layman's terms or have a step by step guide...
11-29-2019, 08:09 AM -
by Slug DawsonHello all. I have target points on my CAD model that I will need to probe during programming. The drawing has XYZ IJK clearly defined for each of the...
12-10-2009, 03:38 PM -
by silvioHi everybody,
I am starting to use our new acquired CMM arm. My question is about the use of the imported CAD model in PC-DMIS measurement...-
08-14-2019, 07:43 AM -
by ShankCrusherOk I think I screwed up. I had an existing program, part had revision, so I replaced cad file with new one. Ran the manual alignment... (I remembered...
05-08-2014, 09:04 AM -
by DarrollhI think I have asked this before but I cant seem to find the post. Does anyone here use CAD = Part? If so, does it help when you bring an off-line program...
09-05-2018, 10:09 AM -
