I’m using legacy dimensioning and have a question about best fit. To keep it simple, if I have a 4 hole pattern to datum A|B. A being the plane the pattern is on and B being a hole in the center of the 4 hole pattern. What is the proper best fit alignment for a A|B datum scheme? I normally would pick up the pattern by using one of the holes as a “C” datum for rotation so I get good hits. Recall that alignment with origin on A|B. Then 2d best fit min/max rotate and translate. Is rotate AND translate right? Or does rotate and translate only give me the deviation from the pattern to its self. Even if I am origin on A|B. The numbers look like they are coming from the center of B. But I was concerned it was “cheating”
Best fit pattern
I have a few questions about best fit alignments and how they relate to print call outs. It is my understanding that when checking a pattern of holes...
02-25-2014, 03:39 PM -
by GREGFHello I was wondering about best fitting bolt hole circle when one is NOT designated as datum -C-.When all holes in a pattern are picked and then 2d rotate...
03-26-2018, 02:26 PM -
by AuRulesJust wanted to ask for a little help on Best Fit Alignments. 30 years of programming and never used Best Fit at all. Always the old 321 alignment or Iterative...
01-28-2020, 12:27 PM -
by dwadeNeed hsome help in explaining how a best fit alignment using translate origin and rotate works. I've got a part with 6 circles (use these for XY origin...
01-18-2010, 02:14 PM -
by JoBLOCKDoes any one have step by step on how to do a Best Fit alignment. I have a bolt hole pattern, and I never used best fit bofore.
12-20-2008, 04:47 PM -
