Hi guys.
I recently built a new star probe. I added two 90° angles to the file (A90B90, and A90B-90). when turning A to 90, probe tip 5 will not calibrate because it is standing straight up in Z. I deleted the two tip 5 probes from the list, but when I went to perform the autocalibrate, one of the two tips reappeared with the asterisk beside it indicating that it needs to be calibrated. I can delete that single tip from the list, and it will disappear, save and close the file, but when I reopen it, the tip shows back up.
Autocalibrate crashes every time I try to run it. I have tried deleting the tip, then running the program. I have tried using user defined order to bypass that tip, but it still shows up in the order. I have tried to skip that tip, and I have tried to jump the step, but it will not allow me to go to any tip but that one.
Does anyone have any idea how I can get rid of this tip so I can calibrate all my tips together?
