Error 170: Probe won't Rearm
  • Error 170: Probe won't Rearm
    Is there an easy fix to this error, or we have to bring someone in to fix the machine?
    I rebooted the whole system, changed the probe, checked the wiring but no success.I am new to CMM programming, so I am still learning. Has anyone faced something similar?
    I had this problem before. It usually means the module is bad. Change the module and see what happens
    • Douglas
      Douglas commented
      I've traced it to dirty surfaces on the magnetic module, or poor/loose connections more often than bad module, the module is the last thing I'd try but that is just me I guess
    There are many factors, most common, as pointed out, is a bad {something}, may not be the module, though. What probe system are you using? Stylus length? Module force?
      Thank you, everyone, for your inputs. I cleaned the probe connections and the error message disappeared.
      • 314RK
        Unknown Probe Error
        by 314RK
        I keep getting the "unknown probe" error every once in a while. I'll recalibrate everything right before running, it'll run a few parts and...
        02-03-2023, 01:30 PM
      • sscandlon
        Error message probe unseated
        by sscandlon
        how do i fix the error , ERROR CE .S%1 .TRCE .0x14000082 Probe unseated after the auto retract movement ?...
        08-24-2020, 02:51 PM
      • GunLake
        Need new probe?
        by GunLake
        New to PC-DMIS and CMMs, My experience is in Polyworks and Romer Arms.
        So about weekly i calibrate the probes. My 50x3 is fine, It'll...
        09-25-2019, 12:45 PM
      • robertw
        Dfncdh
        by robertw
        Hello Everyone,
        Occasionally our Leitz (running Quindos 6) 'stalls' with error S_2 CMWAIT CMWT$2 (A COM error I think). A simple 'Gold Enter'...
        02-03-2010, 10:52 AM
      • Calvin.Korver
        TR_FG014 Wrist Error
        by Calvin.Korver
        I have been getting an error on my CMM when it changes probe angles. It is the TR_FG014 Wrist Error. I have been looking through the forum and have found...
        05-05-2020, 09:54 AM
