'Wild' Plane creation
  • 'Wild' Plane creation
    Created an auto plane with Radial selected, 3 hits, 1 row---create---23 hits populate the feature
    PLN_14       =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,TRIANGLE,LEAST_SQR
                  THEO/<-0.504751,9.403675,0>,<0,0,-1>
                  ACTL/<-0.504751,9.403675,0>,<0,0,-1>
                  TARG/<-0.504751,9.403675,0>,<0,0,-1>
                  ANGLE VEC=<-1,0,0>,RADIAL
                  SHOW FEATURE PARAMETERS=NO
                  SHOW CONTACT PARAMETERS=YES
                    NUMHITS=3,NUMROWS=1
                    SPACER=0.5
                    AVOIDANCE MOVE=BOTH,DISTANCE=0.25
                    USE BOUNDARY OFFSET=NO
                  SHOW HITS=YES
                    HIT/BASIC,<-0.27257,6.329291,0>,<0,0,-1>,<-0.27257,6.329291,0>
                    HIT/BASIC,<-0.27257,6.824558,0>,<0,0,-1>,<-0.27257,6.824558,0>
                    HIT/BASIC,<-0.27257,7.324828,0>,<0,0,-1>,<-0.27257,7.324828,0>
                    HIT/BASIC,<-0.27257,7.825097,0>,<0,0,-1>,<-0.27257,7.825097,0>
                    HIT/BASIC,<-0.27257,8.325367,-0.000001>,<0,0,-1>,<-0.27257,8.325367,-0.000001>
                    HIT/BASIC,<-0.27257,8.825637,-0.000001>,<0,0,-1>,<-0.27257,8.825637,-0.000001>
                    HIT/BASIC,<-0.27257,9.325907,-0.000001>,<0,0,-1>,<-0.27257,9.325907,-0.000001>
                    HIT/BASIC,<-0.27257,9.826176,-0.000001>,<0,0,-1>,<-0.27257,9.826176,-0.000001>
                    HIT/BASIC,<-0.27257,10.326446,-0.000001>,<0,0,-1>,<-0.27257,10.326446,-0.000001>
                    HIT/BASIC,<-0.27257,10.826716,-0.000001>,<0,0,-1>,<-0.27257,10.826716,-0.000001>
                    HIT/BASIC,<-0.27257,11.326986,-0.000001>,<0,0,-1>,<-0.27257,11.326986,-0.000001>
                    HIT/BASIC,<-0.27257,11.827256,-0.000002>,<0,0,-1>,<-0.27257,11.827256,-0.000002>
                    HIT/BASIC,<-0.77257,11.827256,-0.000006>,<0,0,-1>,<-0.77257,11.827256,-0.000006>
                    HIT/BASIC,<-0.77257,11.326986,-0.000006>,<0,0,-1>,<-0.77257,11.326986,-0.000006>
                    HIT/BASIC,<-0.77257,10.826716,-0.000006>,<0,0,-1>,<-0.77257,10.826716,-0.000006>
                    HIT/BASIC,<-0.77257,10.326446,-0.000006>,<0,0,-1>,<-0.77257,10.326446,-0.000006>
                    HIT/BASIC,<-0.77257,9.826176,-0.000006>,<0,0,-1>,<-0.77257,9.826176,-0.000006>
                    HIT/BASIC,<-0.77257,9.325907,-0.000006>,<0,0,-1>,<-0.77257,9.325907,-0.000006>
                    HIT/BASIC,<-0.77257,8.825637,-0.000005>,<0,0,-1>,<-0.77257,8.825637,-0.000005>
                    HIT/BASIC,<-0.77257,8.325367,-0.000005>,<0,0,-1>,<-0.77257,8.325367,-0.000005>
                    HIT/BASIC,<-0.77257,7.825097,-0.000004>,<0,0,-1>,<-0.77257,7.825097,-0.000004>
                    HIT/BASIC,<-0.77257,7.324828,-0.000004>,<0,0,-1>,<-0.77257,7.324828,-0.000004>
                    HIT/BASIC,<-0.77257,6.824558,-0.000002>,<0,0,-1>,<-0.77257,6.824558,-0.000002>
                    HIT/BASIC,<-0.77257,6.374315,0.000001>,<0,0,-1>,<-0.77257,6.374315,0.000001>
                  ENDMEAS/
    Also had other features do some crazy stuff also, like cylinders that take hits out of sequence.
    2019R2
    Do you have void detect on by chance? That will cause it to relocate the hits, and I have had the points taken out of order because of this.
      One other weird thing is that a radial pattern should be number of rings, not number of rows.
      If you were doing a square pattern the smallest number of rows should be 2 not 1.
      Definitely looks like some wires are crossed in that plane.
      PC-DMIS 2016.0 SP8
      Jeff
        Anyone using 2019R2 seeing the same? If so, please report it as a bug.
        PC-DMIS CAD++ 2o19 R1 SP11
