Report Window
  • Report Window
    How can I set up the report window so that I only get the dimensions? Do I have to make it a custom report or am I missing some settings?
    What else have you got?
    Features, moves, alignments etc? What version are you on?
    Applications Engineer
    Hexagon UK
      EDIT WINDOW LAYOUT.
      You can select what it shows for the EDIT WINDOW and for the REPORT WINDOW, each is it's own
        Here is an attachment. I've tried turning things on and off in the edit window and report window. This is in the text only report form. I would like just the dimensions in this form. Thanks.
          I'm using 2019 R1
            What do you mean by "dimensions"? Everything in that report *is* a dimension, so what part do you want to hide?
            You can try right-clicking in the Report Window on the part you don't want, and select Hide...
              In the Editor turn TEXT OFF, Then REFRESH your Report.
                Or If you want it to look like this.
                Then Click on F10 and choose what you want to display.
                  or if you want it to be really just text, you have to right-click in a 'blank area' of the report, select EDIT OBJECT, and mark "use text mode dimension reporting"
                    Here are two more attachments. I just want the header and the measured dimensions. Position, diameter, ect. I have tried all of the suggestions. Thanks. But I cant seem to get this so that I only see the measured dimension that I need to report. Ok. I did what Anders said and I hid the things I don't want. Do I need to do that ever time. Can I make it my default? I am new to this so I appreciate the help.
                      on the report window-you have a Set as Deafult option. it's right next to the print and it looks like a checkmark
                        Maybe look into Print Commands, and also where Matt told you to right click choose always for the header.
                        I'm programming offline v2012mr1. I am looping the program using external alignments (no loop commands in the program). I have a print command set up to
                            Okay, so (as other have alluded to) these are the Textual and Graphical components of the dimensions.
                            You will need to switch it off (as Kirbs showed in post #7 or Michael_Swe showed above) for ALL existing dimensions. You can use Find & Replace to do this.
                            When you next create a dimension make sure the Text and Graph options are not ticked, PC-Dmis should remember this setting for subsequent dimensions.
                            Hexagon UK
                              Thanks everyone. I've got this figured out. Much appreciated.
                              • KIRBSTER269
                                KIRBSTER269 commented
                                Show your results so others may learn, a simple " I've got it figured out " doesn't help others
