So, I have eleven of these diameters on this angled surface I've tried a scan but it doesnt follow the contour of the I.D., I have a picture of an auto circle but its off on the bottom, and I can auto circle each diameter as a half which will probe evenly but then im not able to construct a 55mm diameter circle out of those two circles, which all eleven of these have a true position callout so my question is can i angle my auto feature to get this data??? H2.JPGK1.JPG
Diameters on Angled Surface
- 1 like
Perimeter scan would also work. Is this an angled plane or contoured plane? If it's just an angled face, pick up a plane around the hole and align to it or use sample hits prior to probing the circle. If it's a contour, does the print define the angle at which the circle /plane s located?
You could take a 2D circle out of the equation and perform 2 layers of perimeter scans and construct a cylinder.
It looks like the 'cylinder' is not punched perpendicular to your surface - this means you're actually following an ellipse if you are following the inside of the 'cylinder'.
Maybe you could try F5, Show Extended Sheet Metal Options, and select Use Pin in the Auto Circle dialog. See more in the Help:
PinPunch.PNGAndersI
- 1 like
- 1 like
Maybe - depends on how thick the material is. Two half-circles should still be relatively simple, you would just need to construct a full circle out of them afterwards.
the pitch wont extend to the material thickness on the bottom, i can do two half circles, but when i try and construct one full out of the two halfs it tells me i cant and the math failed etc....???
Constructing a circle out of 2 halves you would need to be in the correct workplane, have the 2D option selected, and you may need to extract the points. CIR1.HIT[1..CIR1.NUMHITS], CIR2.HIT[1..CIR2.NUMHITS],, would be changed from the normal CIR1, CIR2,, feature list in the constructed feature.
Create an offset CS to where the feature is supposed to be, then measure the hole with 3 pt sample/3 point ID, origin XYZ from that then scan relative to that CS. Tolerance to the CS as specified in FCF.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Anyone else running into sizing issues on the circle auto feature?
I have a pin that's designed at 21.5 mm. I verify that it's designed at...-
07-17-2017, 08:54 AM -
Hai everyboddy
Im curious about one ting and one ting only
When measuring a diameter, is there any rule on what to level to or how...-
12-09-2020, 11:42 AM -
by russdHello all. I was rushed to write a program and now I'm trouble shooting the program and this is one of the features that has come up for discussion recently....
12-21-2011, 03:36 PM -
by TKOFaithHi all!
I'm running 2013 mr1. In the last week I started having some strange occurrences with auto circles. It doesn't happen with all...-
08-04-2014, 05:29 PM -
by Amdgk
Hi all,
I am completely stumped at the moment so any help would be greatly appreciated!
The attachment...-
02-24-2012, 05:48 AM -
