I have a product that requires me to perform several evaluations using a minimum of 180 points per plane/diameter. Within this request is a percentage that must be maintained in a secondary set of boundary for diameter. We would like to output Min/Max and Percentage within boundary.
When I attempt to 'pierce' the scan with a line at specific angle PC-DMIS errors and tells me the features do not converge. If I select 'construct circle' and select the scan, the pierce will work, but returns the PR as half the reported measured diameter(Pre-averaged). This removes the form error and generates a 100% conformance or non-conformance to the percentage requirement as well as showing no diameter variation.
Is there a way to access the scan data at specified ANGULAR locations so no matter how many points the CMM collects so that I can always get my 90x required cross sections?
