recall machine specific parameters using one program
  • recall machine specific parameters using one program
    I am sure this question has been asked before. We have multiple CMMs all running PC-Dmis 2013 MR1. What they want to be able to do is use the programs across the different machines, I know that fixtures will have different alignments. What I want to know is how do I set the program to recall the different machine specific parameters that could effect the program running
    Create a text file with a standard name at a standard location on the hard disk (where every user can read it), containing the parameters in a specified order, on each computer.
    Start every program with file I/O-commands that read the parameters stored (in the specified order) from those files into variables, and use those variables in parameter setting commands..
      I have been asking my leader about letting me take some more classes at Hexagon, but keep getting told money is tight. Do you have a sample of what the text file would like as well as a sample of what the code for PC DMIS?
      Also are you aware of any good reference material I could buy that would help me. I apricate all the help that I have received in the past.
        Short of taking the Level 3 class, you can start by going through the Using File Input/Output chapter in the Core Help File of the manual.
        7107 Global Classic TP20
        2019R1 SP1 CAD++
        • Radar
          Radar commented
          I have started to read through that last night. The company I work for, thinks because I went through level 1 that I have learned everything there is to know.
      • thomas pilc
        one program two machines
        by thomas pilc
        hello everyone what i am trying to do is have one program for 2 different size machines one is 7-10-7 and the other is a 9-12-8 both have the same scanning...
        11-05-2018, 11:29 AM
      • spsayeski
        External Alignments
        by spsayeski
        I am trying to use one program for two different CMM's. I am trying to have an external alignment for each CMM due to the home position being different....
        10-02-2008, 07:59 AM
      • Chally72
        Preparing for more CMM's
        by Chally72
        We are about to add several new CMM's to our shop, and possibly convert an old one to PC-DMIS. I have been learning on the fly for the past year, so I'm...
        09-02-2009, 07:43 AM
      • Mikeg
        Adding another CMM
        by Mikeg
        We just got a new CMM and I am looking for input on setting my programs up. The new CMM is a global 555 (same as our other one). I plan on adding an input...
        04-27-2017, 02:33 PM
      • BKulpa
        Optional probe parameters
        by BKulpa
        Does anyone out there use variables to assign optional probing parameters?
        I'm thinking of using a file on the local drive of the machine to store...
        05-15-2014, 12:25 PM
