Question for those with more experience than I. I am looking for a way to take a scan of a spherical feature on a project I am working on. I know I have seen scans done on spherical IDs before but I cant for the life of me remember how. Sitting here when its slow trying to optimize programs and I hit a roadblock with this and it just wont leave my head trying to figure it out.
There doesn't seem to be any scanning strategies on an autosphere, so I guess the only way is to
- measure the sphere with a suitable number of touch hits
- align (origin) to the sphere
- scan a number of arcs on the sphere (create one, paste with pattern [rotation] to get the others)
- construct sphere from all the scanned hits
Originally posted by AndersI View PostThere doesn't seem to be any scanning strategies on an autosphere, so I guess the only way is to
You can also scan circles at different heights, then construct a bfre sphere, or use constructed filters / sphere.
If you use basic scans, you can select "conical scan" if you don't scan at the equator.
If you're trying to scan "on section" - for example, around the equator to look at circularity - you might want to consider using the adjust filter
https://docs-dev.hexagonmi.com/pcdmi...ted_Filter.htm
Originally posted by JEFMAN View PostYou can also scan circles at different heights, then construct a bfre sphere, or use constructed filters / sphere.
Originally posted by JEFMAN View PostIf you use basic scans, you can select "conical scan" if you don't scan at the equator.
The Conical scan check box allows for proper scan compensation on cones or spheres. This check box lets you scan more quickly when not perpendicular to the part surface. PC-DMIS continues to monitor the probe force as needed.
BFRE is imperative if you scan circles at different heights, as the circles themselves will be probe compensated at an angle to the surface..
"conical scan"? How would PC-DMIS know which direction to probe compensate? I see the minimal text in the Help
Does this mean that surface direction is taken from the probe force deviations? If this is a good way, why isn't it always used automatically? What about friction drag on the probe - that will give a partly wrong direction for compensation, the more the higher the friction (and let's not talk about bumps and scratches...).sigpic
Does this mean that surface direction is taken from the probe force deviations? If this is a good way, why isn't it always used automatically? What about friction drag on the probe - that will give a partly wrong direction for compensation, the more the higher the friction (and let's not talk about bumps and scratches...).)
Thanks for the advice everyone, we are on 2014 and I DO have CAD, so I will experiment with it today. I wish that spherical scan would be something that could be added to make this possible. Just having it take the nominal vectors and apply it into rows of scans along the sphere would simplify this whole process. I know I have seen it done before but couldn't recall how.
I had tried a few different scans but the data never came out correct, so I am assuming it is the recomp that will correct the error I am seeing from the vectors being incorrect.
Just a thought about programming a circular scan on a sphere, if the cut plane doesn't contain the center of the sphere.
Then, the programed height and radius are different than the contact ones.
Depends if you know the height of the center ball ot the height of the scan that you want (contact height) :
So, in PC-DMIS, if you want to scan at 45° :
ASSIGN/HCONTACT=SPH1.R*SIN(DEG2RAD(45))
ASSIGN/RBALL=(PROBEDATA("DIAM")/2+PROBEDATA("PRBRDV)
ASSIGN/HPROG=(SPH1.R+RBALL)*SIN(DEG2RAD(45))
ASSIGN/RPROG=(SPH1.R+RBALL)*COS(DEG2RAD(45))-RBALL
- 2 likes
by zeljkoHello,
I tried to insert scan and when I executed program, machine doesn't do scan, but touching? Also, when I add auto plane feature with...-
05-10-2018, 03:51 PM -
by Tomi530iGood morning all
I have a nooby question.
When I'm using auto feature I can change the measurement strategies to Adaptive Scan...-
02-08-2016, 07:19 AM -
by shawwwnTrying some scanning. Using a CAD model, i want to scan a 2d , 90 deg corner radius. when i create the scan from my model the probe scans the feature....
05-07-2008, 12:18 PM -
by robehor4Is there a way to use Grid scan with a SM25 scan head and not use points but maintain constant contact?
09-19-2007, 03:03 PM -
by TestedI have mirrored a part program and all works well except for the scans. The program jumps right over them "it will not measure them at all"....
01-09-2007, 08:09 AM -
