here :
http://software.hexagonmi.com/public...e/2019_R2/SP2/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R2/SP2/x64/
Release Notes - 2019 R2 SP2
• PCD-146773 - Fixed an issue with the Outlier filter where you couldn't apply it to auto circles and line features.
• PCD-151139 - Fixed an issue where a double-click didn't open a measurement routine file. Instead, PC-DMIS displayed an error about a bad archive.
• PCD-155563 - Fixed an issue where the B5 controller would not accept any commands from PC-DMIS when it's in PARK mode. This fix ensures that no temp comp commands are sent to the B5 controller until the ENDPARK status was set in the measurement routine.
• PCD-161289 - Fixed a crash that occurred when you tried to calibrate additional tips after a tool changer calibration.
• PCD-162867 - Fixed an issue that occurred when you opened or edited an old custom report.
• PCD-167498 - Fixed an issue where an incorrect diameter was computed when you box-select a laser cylinder feature from a COP.
• PCD-170533 - Fixed an issue where the software deletes the LampDefinitions.xml from the ProgramData folder when you reset PC-DMIS.
• PCD-171391 - Updated the HR-MP rack calibration measurement to account for a design change in the production rack. This fix also allows the TP20 probes to be used with the HR-MP rack.
• PCD-173138 - Fixed an issue to allow PC-DMIS to show snapshots in landscape orientation in report templates.
• PCD-173438 - Fixed a crash in summary mode that occurred when a start block command was used without an end block command.
• PCD-173470 - Fixed a crash that occurred when you tried to open the Thickness Scan dialog box after Quick Linear scans.
• PCD-173545 - Fixed the issue where silent or passive install modes failed to install on network license servers.
• PCD-174088 - Fixed an import VISI issue where the surface colors were not correct.
• PCD-174370 - Fixed Solidworks tessellation issues.
• PCD-174472 - Removed the unneeded blank space in the Axis field to correct the value in the statistics.xml for legacy profile dimension.
• PCD-174473 - Corrected a probe drawing issue.
• PCD-174982 - Fixed an issue where the Scale Drawing dialog box would not open from the Shift+Right-mouse button combination.
• PCD-175419 - Fixed an issue where the camera ID for a vision probe was changed, but any existing optical calibration data was not deleted.
• PCD-175673 - Fixed a crash that occurred when you used the Analysis window on a custom report.
• PCD-175777 - Corrected DMIS syntax for the MEAS/ENDMES block.
• PCD-175818 - Fixed an issue where PC-DMIS would not open an Online measurement routine from the Home page on a Portable system.
• PCD-175846 - Fixed the issue where filtering didn't work as expected because the conversion from decimal to percentage was missed when calculating the point reduction filter value in Laser Scan dialog boxes.
• PCD-176129 - Fixed a crash in a dual arm machine configuration that occurred when you used Arm 2 to measure a point in manual mode and clicked the Done key on the jogbox.
• PCD-176574 - Fixed a crash that occurred when you used nested groups.
• PCD-176641 - Fixed an issue that caused some torus surfaces in IGES imported files to not render properly. This was an issue especially noticed in IGES files that were exported out of TubeShaper.
• PCD-176746 - Added a change to our service pack policy that requires a Software Maintenance Agreement for installation.
• PCD-176898 - Fixed an issue that occurred when you set the SkipNumberOfStripes registry entry in the Settings Editor application to -1. This value indicates that no purple scan stripes were visible in the Graphic Display window for the active scan pass. Once the scan pass was finished, the graphically rendered blue pointcloud was seen.
• PCD-177036 - Fixed an issue related to Euler transformations where the I++ server can do ScanCircle features with HSSDAT and set a manual retract.
• PCD-177426 - Fixed a software error that occurred because of a startup timing issue.
• PCD-177452 - Fixed an issue in the feature extraction where laser features were measured relative to others.
• PCD-178020 - Fixed an issue where readouts of x, y, z, a, and b were corrected for I++ server.
• PCD-178572 - Fixed an issue with the TempComp for the Wenzel version of the I++ server that supports GetProp/SetProp part.
• PCD-178618 - Fixed an issue where the hardware component name was corrected from Senmation_HP-S-S-X5 to Senmation_HP-S-X5.
• PCD-178990 - Fixed a typographical error which caused a tip to report a thickness of 0.
