So, this datum target scheme I've never seen layed out this way before for datum D, I was going to go iterative for alignment, then what I was going to do is fixture the part on standoffs on datum A surface for my Z, then use B as my X origin and C as my Y origin. They dont require any callouts to datum D so I thought that was odd, as far as defining datum D I was going to use a 3mm ruby, measure a circle around the O.D. and then create theoretical points in the 4 target locations, but kinda confused on why they have this in here if nothing is relating to it in the FCF's, wondering what you guys think for tackling this or how you would align to datum D if you needed too???
Strange Datum Targets Advice Welcomed!!!!
B would be my X,Y origin, C stops rotation with 22.5 degrees offset alignment, 4 points at 0, 90, 180 and 270 degrees make datum D. Check other views, sections for D being called.
Align to A B and C. Pretty simple. Use the 4 target points to measure Datum D as a circle. If Datum D isn't used in a FCF anywhere on the print, then ignore defining it, or go back to the customer or engineering and see if they missed something. I have seen Datums called out on a print that are referenced to another drawing for an assembly.
- 1 like
I took A as a plane leveled to zplus, then took b as a circle for my x,y origin, then c i also used a circle but when i rotate to xplus 22.5 it spins my cad, so i made a line from C to B and rotated that 22.5 degrees offset and it didnt spin my model, how would you go about that issue if I didnt want to use a line?
Originally posted by marcc View PostB would be my X,Y origin, C stops rotation with 22.5 degrees offset alignment, 4 points at 0, 90, 180 and 270 degrees make datum D. Check other views, sections for D being called.
If Datum D isn't referenced at all on the print, it could be used to clarify how they expect you to measure that feature of size Ø423 ±1 [TP][Ø1][A][B][C] on its own.
Or it could just be remnant crap from a drawing revision that was done by someone who had no idea what they were doing.
--They likely removed a FCF reference to D, and didn't remove the datum targets. (this is where i would place my bet)
as far as ABC align:
Construct a line between B and C centroids
Level A to Z axis.
Rotate to BC line about Z
Translate Z to A
Translate X & Y to B
then Rotate about Z -22.5° to take your four D target hits.
Like marcc said, make sure D datum target points don't have a defined location (depth from A datum) in another view. if so, be sure to take your hits relative to that basic offset from A.
by jcallHi All,
I have a primary Datum (A) which is on 2 contoured surfaces (marked in red on image)
I need to define Datum A in PCDMIS...-
06-30-2016, 11:21 PM -
by jaca_232Good afternoon.
first time I have to deal with this in pcdmis. im gonna post a sketch of the part looking for some advices to align this part....-
06-11-2018, 03:25 PM -
by BWIZZLEif you have a non planar surface as your primary datum, what are some of your options to measure datum per ASME Y14.5 spec? Can you just pick any 3 points...
06-01-2016, 08:51 AM -
by JPedroHi buddies
I have a print that it dont have datums only the datum -B-
I need align that for check some features, I neither...-
02-25-2010, 08:44 AM -
by unchartedI wanted to make sure but can someone tell me can you use a datum target that has a draft to it as an actual datum? This is the only target with a draft...
09-11-2014, 02:47 PM -
