Scanning and measuring a chamfer with a profile tolerance
  • Scanning and measuring a chamfer with a profile tolerance
    Hello All,
    I am having trouble with scanning a chamfer to report profile of a surface. I was thinking if taking multiple rotors scans, but I just cant seem to get it to work right.
    The chamfer lays on a 2.00 dia. And yes profile of a surface on a chamfer.
    Suggestions?
    TIA!
    Construct a bfre cone from scans and dimension it ?
      Do you have CAD? Take Autopoints on the chamfer, construct a feature set from them, and dimension profile of the feature set. If you don't have CAD, can you create an autocone on the chamfer typing the dimensions in? Then you can dimension the profile of the cone.
      PC-DMIS 2016.0 SP8
      Jeff
        Wouldn't creating and measuring a cone give me an average of the cone instead of evaluating each point on the surface?
        How do you create a circular scan of points without it being a circle?
          FYI.
          Creating a cone is incorrect. It is only an average and not evaluating every point.
          In my opinion and how I was trained from an ASME board member...all POINTS on the surface must fall within the profile tolerance zone. Not a cone or so forth.
            Originally posted by FAMOUSX1 View Post
            FYI.
            With PC-DMIS you can check the profile of lines, circles, cones, cylinders, etc. and it does evaluate the individual hits for that feature. In the example below some hits are up to .00015 in the plus material direction and some are up to .00012 in the minus material direction.
            DIM PROF1= PROFILE OF SURFACE OF CONE CON2    FORMANDLOCATION  UNITS=IN ,$
            GRAPH=OFF  TEXT=OFF  MULT=100.00  ARROWDENSITY=100  OUTPUT=BOTH
            AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL        MAX        MIN
            M      0.00000    0.00045    0.00045    0.00027    0.00027    0.00000    0.00015   -0.00012 ---#|#---
            PC-DMIS 2016.0 SP8
            Jeff
