I would say yes. I use rubies on inconel all the time. Here's what Renishaw says...
Ruby can suffer adhesive wear (pick-up) on aluminium under extreme conditions, but performs well in most applications. • Ruby is the best material on stainless steel and titanium. • Silicon nitride is a good substitute for ruby in extreme aluminium applications, but suffers from abrasive wear on stainless steel and cast iron. • Zirconia is the optimum choice for scanning cast iron components. • Tungsten carbide also performs well on cast iron.
7107 Global Classic TP20
2019R1 SP1 CAD++
I've only ever used ruby when probing nickel alloys (both on-machine probing and CMM use). We have been using Ø3mm ruby x 50mm ceramic shank stylii for the past 20 years on some of the machines and have only ever replaced 3-4 over that period, all due to human error and all failed by a clean break on the shank. Our CMMs were outfitted the same. This was on cast surfaces, machined surfaces, ECM surfaces, Inconel, HastX, Waspalloy, PWA alloys, RRC alloys, single crystal, directionally solidified parts, etc.
I'm looking for the proper stylus material for Manganese Aluminum Bronze. I know Silicon Nitride is suggested for aluminum, but am unable to find out...
What kind of probe life are other people experiencing when scanning? We do a lot of scanning. Aluminum parts, silicon nitride probes, hexagon recommended...
I have been told that its not a good idea to do scanning on aluminum with a Ruby tip as the aluminum will tend to build up on the tip. I am going to have...
