Accuracy and spec
  • Accuracy and spec
    When my quality manual states use measuring equipment with a minimum accuracy ratio of 4 to 1, meaning product tolerance to equipment tolerance. How does that works with CMM's? what is my equipment tolerance, I am assuming its the same thing as accuracy?
    What do I look for in the Calibration certificate? is it MPE? or what?
    Help
    B&S One
    PC-DMIS CAD v2014
    Romer Infinity
    I would just use the tolerance formula of the cmm (x+L/xxx) on the min case.
    I don't mean that the uncertainty is this value (there are very different !), but in a quality world, there's no reason to use another value for a cmm than for a caliper.
    For a caliper, you can use the calibration value, here, it's hard, so using the mpee should be enough.
    Just my opinion...
    • WolfMan
      WolfMan commented
      There is a formula for Maximum Uncertainty of Length Measurement and The maximum permissible indication error. I am assuming the MPE is the one I need.
    Even if it's not really true, the MPEe certify that the measurments error on a length are lower than the corresponding value.
    I don't know exactly about the max uncertainty, but I believe that it's the uncertainty calculated during the calibration, takig into account some parameters like temperature, MPEp, uncertainty of calibration of the artifact, of the standards used (...). It's valid only on 2D distances.
    It's imposible to use this value if you measure a classical part, like a LS circle.
    If your QM doesn't know to much about cmms, using MPEe should be enough.
    If he knows a little more than nothing, then you will have to proove what you say, and in this case, good luck !
    Calculating an "global" uncertainty seems (to me) to be impossible, you should have to calculate it for each feature (dimension, location, form...), taking into account the cmm, the probe, the part and the method !!!!!
    bis, just my opinion...
    • WolfMan
      WolfMan commented
      Jefman, I am not trying to calculate uncertainty. I want to know which of the values I need to use to comply with 4:1 rule.
    If your dimension is approaching "state of the art", that 4:1 ratio is subjective to your level of risk.
    I would consider any non-linear dimension tolerance of <0.0004" would be considered approaching state of the art.
    Linear tolerances, I would consider state of the art <0.0001"
    Again, these values are subjective. Maybe if I had better equipment, these arbitrary values would differ. Other contributing factors will always compound this confidence interval (environment, bias in fixturing or part setup, etc)
      I know some customers require a Gage R&R study on critical dimensions to verify repeatability and reproducibility of the measurement system used. Error must be no greater than 30% (measurement deviations/tolerance), anything under 10% is excellent. Perhaps that's why its in the Quality manual, so if it ever was required, there's a good chance you'd be able to meet that requirement.
      • Ken8282
        Accuracy
        by Ken8282
        I have see number similar to these when talking about accuracy. MPEe 2.1 + L/250. Forgive my ignorance but what do they mean.
        11-09-2018, 07:26 AM
      • Hi-Tech Redneck
        CMM Accuracy
        by Hi-Tech Redneck
        Maybe this is a dumb question but I gotta ask. Had calibration performed by Hexagon last month and maybe I should have asked the Tech. Where, if anywhere,...
        11-14-2014, 09:54 AM
      • Kevin Watts
        another quickie
        by Kevin Watts
        cmm calibration just finished and shows total volumetric performance whatever at .0006" Is this acceptible, he says no adjustment is needed, yet...
        07-10-2007, 05:26 PM
      • abullo01
        Minus minus tolerance
        by abullo01
        Hello all,
        I am fairly new to CMM work and am trying to find information on the correct way to tolerance some thing written as a diameter...
        07-31-2015, 08:50 AM
      • WolfMan
        Gage Block Sets
        by WolfMan
        Good morning fellas. I have a question, we recently ordered a Gage Blocks Set AS-1 grade. We use them for general purpose and adjusting our tools. (Not...
        01-07-2014, 07:56 AM
