Is there a way to construct features out of specific sections of a freeform scan? Say I wanted points 26-30 constructed into a circle. I think I could do it by assigning variables to the specific hitpoints, but I'm hoping there is an easier way.
Constructing features out of Freeform Scan
Click construct circle and select the freeform scan. Create it with your specified parameters to get the feature constructed in the Edit menu. It might or might not pop out a math error. In your constructed circle feature, find the line CONSTR/CIRCLE,BF,2D,SCN1,, and add the .hit extension to the name so it has SCN1.HIT[26..30].
- 1 like
You can select areas of the CAD model instead of the points and it will only extract the points in between the areas selected. You can remove outliers if you choose to also. No need to know which points are needed exactly.
SingularitY: I didn't know you could do this I need to go test this out I used to extract individual scan points then create features from those points. Could you give details I'm not getting it to work out on trying to construct a cylinder from freeform scans that are scanning 3 surfaces.
Does anyone have any ideas on why the second line of my profile is so far off? Struggling to find where I screwed up.
Based off how it's shifting the DRF for the lower section, my guess is that is calculating incorrectly. PC-DMIS likes to corrupt Xact Measure dimensions sometimes. If you haven't already, try deleting and recreating the dimension and see if that helps
I've recreated A, the feature in question, and the characteristic, still get a dev > 1. I've never fed Xact anything, do I literally just put the MMC size of Datum C in the control frame?
Any GD&T experts have an opinion on that second profile characteristic? Datum A is +Z plane, and the features in question are radially perpendicular to it.
Using 2019 R2Last edited by RanDawgg; 11-20-2019, 10:06 AM.
As Mike said, your report is not matching the FCF you showed us, so there's some disconnect there that is confusing the issue. The shift, especially the 270 rotation shown on the second segment is a major red flag. Something is going wrong with how you're measuring the feature or your method of creating the Xact FCF. Try to dimension them in two separate profile dimensions. It's the same when your profile isn't called out as a composite.
The second segment is there to control the form of your profile to a tighter tolerance. To make sure all your curves are looking good ^^
In Xact Meas, check the custom DRF in the lower-center of the Xact image you posted. This will show you the 6 degrees of freedom how Xact sees them to be (x,y,z,u,v,w)
As for the MMC, yeah, you need to tell it what MMC is. For xample it C is a outside dia of nominal Ø.250 ± .005, you'd enter .255 in the grayed size area of :
[Ø<size>] to look like [Ø.255]
by karthikeyanI need to recall seperate features from linear scanned profile (using number of points from cloud). I tried but i don't know how to do exatly. Need help...
12-25-2018, 11:30 PM -
by gcunniffIs there any way to change the size of points displayed in the graphics display window? I doing some scans using single point and while it displays a...
05-01-2007, 02:41 PM -
Tried using the search function, couldn't find anything.
Basically when I create a scan (or any feature, but more annoying with scans) the...-
10-26-2017, 11:49 AM -
by FAMOUSX1Hello,
I am new to scanning and I cannot figure out how to create or add scan points.
I am trying to construct a circle out of a scan but...-
01-16-2016, 03:40 PM -
by LaoschbagI'm a 15 year Calypso programmer & fairly new to DMIS...Is there a way to show points on the CAD model that have been scanned for a circle or plane...
05-27-2020, 09:37 AM -
