I am trying to measure perpendicularity of a cylinder to a plane. The physical plane surface is directly perpendicular to the cylinder axis. The issue is my result is always zero. Also tried it as a constructed line using the cylinder and same result. The workplane is correct (-X)....cylinder axis is parallel to Z.
Perpendicularity of a Cylinder
Looks like you haven't run CYL_B yet. Datum A has been run, maybe run the whole thing?(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- 4 likes
Yeah, AndersI but if he or she didn't run CYL_B, then most likely didn't run the feature callout either, I have notice when using Xact, even if you run the features, if you don't run the callout, it doesn't change either, that's why I'll highlight the 2 features and the callout and Execute Block.
I agree with KIRBSTER269 Are you running marked sets? If so, make sure the cylinder is marked for execution.
by wil_sieI need help with dimensioning Perpendicularity. I have a cylinder and a plane, the cylinder is part of the datum structure and the plane is a feature....
10-08-2009, 01:48 PM -
by PCFreddieI made 2 cylinders and want parallelism. Neither is really datum. When I put in cylinder 1 to cylinder 2 I get 0.023mm. But when I put cylinder 2 to...
12-09-2010, 10:16 PM -
by drago8813I am measuring a part where datum feature A is a cylinder and have a perpendicularity to a plane. I aligned using the cylinder as primary and the plane...
04-05-2017, 12:16 PM -
by JBELLCan anyone explain why when I am reporting concentricity from feature A to feature B I get X reading, and when I report from feature B to feature A I...
10-18-2016, 12:50 PM -
by Stephen1055I have 2 (supposedly) perpendicular features.
Why do I get different measurements when I measure perp from A to B and when I measure B to...-
03-24-2015, 10:07 AM -
