Print/Report issue
  • Print/Report issue
    I assume this is a setting issue but no luck searching for one that is not correct. We do have another program with the same code that does work correctly so it has me stumped.
    Code below - PC-Dmis CAD++ 2017 R2 release - Tp20 - Global EVO
    C4 =COMMENT/YESNO,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO,
    Print report?
    IF/C4.INPUT=="NO"
    GOTO/END
    END_IF/
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,APPEND=Z:\Master Part File\641000030\641000XXX\Lot-.PDF,AUTO OPEN REPORT=OFF,$
    TO_PRINTER=ON,COPIES=1,$
    TO_EXCEL_OUTPUT=OFF,
    END =LABEL/
    We have been running this program in Operator mode and it has been working fine until recently. Now it will only run and execute the code here (at the very end of the program) in Administrative mode. When run in Operator mode, the box comes up for location of PDF (starts in directory program is in). Why is it skipping my actual code in the program and going to global print settings?
    A quick search of the forum would have turned up an answer. The current user needs write access to the registry entry "HKEY_CURRENT_CONFIG\Software\PC-DMIS 50 Converter". Contact your IT department, to implement this. This is a Windows/User configuration error that this entry is not unprotected.
    Systems Integrator
    • tami_
      tami_ commented
      I did search and read everything I could about report settings. I know a WiN10 update caused that issue but we run WIN7 and there was no update. I will check it anyway. Thanks.
