Sorry if this has been talked about before, i honestly didn't find anything that could help. I have a cylinder i'm trying to scan. It has a couple holes on the side and my probe scans over those. How do i tell it to skip the holes when scanning? usually with ttp i turn void detection and knows not to go there but with scanning it doesn't help.
Another scanning post
I'm not the scanning Guru and maybe it's not an option in the Auto Features but I'm almost positive I've seen a "Jump Holes" option in the "Basic scan" dialog boxes. Maybe you could build a cylinder for multiple basic scans? I dunno...Sheffield Endeavor3 9.20.8, Tesastar-SM, Leitz LSP-X1s & LSP-X1M, PCDMIS 2011 MR1
I just had this similar issue and couldn't seem to find a solution that worked sufficiently. I ended up changing the amount of rows to miss the holes. Not the best solution but it worked. Also, this CAD looks surprisingly similar to an AR bolt carrier.
Keep your eye on the goal: measure a cylinder, preferably with scanning. The goal is not locked down to "Auto Cylinder" or "Concentric Ring Scans", right?
So you could stick with Auto Cylinder and change strategy to a single spiral scan (which is slightly more efficient and more accurate due to no stop/start prehit/retract) with a large pitch carefully tuned to miss the holes.
Or you could create a series of separate Basic Circle scans inside the bore, shifting their locations to skip the holes, and then Construct a cylinder from them. One neat thing about this is the ability to also Construct circle features from each scan in order to report size and/or roundness changes along the bore.
- 1 like
Originally posted by Hi-Tech Redneck View PostI'm not the scanning Guru and maybe it's not an option in the Auto Features but I'm almost positive I've seen a "Jump Holes" option in the "Basic scan" dialog boxes. Maybe you could build a cylinder for multiple basic scans? I dunno...
Originally posted by zbailey View PostI just had this similar issue and couldn't seem to find a solution that worked sufficiently. I ended up changing the amount of rows to miss the holes. Not the best solution but it worked. Also, this CAD looks surprisingly similar to an AR bolt carrier.
Originally posted by Ego Murphy View PostKeep your eye on the goal: measure a cylinder, preferably with scanning. The goal is not locked down to "Auto Cylinder" or "Concentric Ring Scans", right?
Originally posted by Disal View Post
I don't see anything like "jump holes" or anything similar on the dialogSheffield Endeavor3 9.20.8, Tesastar-SM, Leitz LSP-X1s & LSP-X1M, PCDMIS 2011 MR1
Originally posted by Tater View PostI have not done any scanning with PC-DMIS but, I noticed the void detect is on and that messes up my autocircles and autocylinders........
by ehaisHi everyone
I´m trying to scan a surface wich includes a lot of holes and my question is how to detect the existens of any holes and then...-
08-22-2006, 12:17 PM -
by john donahoeWhy is the cmm crashing at the starting hit point at the end of the scan? I have tried everything I know to stop this but it just keeps happening....
12-27-2007, 12:42 PM -
I can't get my machine to scan small holes (under about 1 inch) in always says that it has been interupted and it always happens at the end before the...
06-25-2007, 08:25 PM -
by ChannyHi All,
I'm wondering if I can get some help with scanning. I am using an SP25 scanning probe, and I'm having very little success....-
02-26-2019, 10:28 AM -
by Wes CiscoHowdy!
So I migrated up to 2012mr1sp3 and have been experimenting with the 'new-to-me' Adaptive Scan strategies. Surprisingly I was willing...-
02-07-2014, 09:57 AM -
